Bonjour, est ce possible d installer un corps de roue libre micro spline pour cassette VTT Shimano 12v 10-51?
Which trainer? If you’re talking about the Zwift Hub, I don’t think there is a microspline freehub body available for it. You would need to use a 12 speed hyperglide cassette.
There is a microspline freehub you can use with Elite trainers.
Bonjour
Oui, c est pour utiliser mon VTT mono 12v cassette 10-51shimano sur le zwift hub.
Il existe peut être un adaptateur micro spline à monter sur le moyeu?
You would need to replace the hyperglide freehub with a microspline freehub, but there is no microspline freehub for the Zwift Hub trainer. The smallest cog that can fit on a hyperglide freehub has 11 teeth. You can buy an 11-50 hyperglide cassette that will work, but the highest gear may be too low. If you don’t get enough resistance using an 11 tooth cog, you can use the QZ app to increase the resistance with virtual gears (qzfitness.com)
Merci Paul,
J ai acheté une cassette SRAM 12vitesses plus simple que de trouver un adaptateur micro spline.
Ça fonctionne parfaitement.
