That is really bad because I have a direct drive trainer (an actual power meter device) that won’t work with event that requires power meter. Mine doesn’t have simulation nor erg mide, it record my actual power and sends it to zwift. I was about to join an elvent when it said “power meter required”, and I paired my elite turbo trainer and kt still didn’t work properly…
Which trainer do you have?
Im guessing you have an Elite trainer using the Misuro B+ sensor, such as the Turbomuin or Turno. These are not actually proper smart trainers, and are very inaccurate which is why they are not allowed.
Also if you are Jon Einar Visser on Zwiftpower, you absolutely should not be allowed to use that equipment. Hitting 6.5 w/kg for 20 min is top world tour climber level, and if this is you i very much doubt that performance
