Hello,
For two days, the power measurement is wrong, it jumps continuously + -20W every second. I attach the log of the application. Thanks in advance.
LOG:
[21:08:52] ANT : Unknown response
[21:08:52] ANT : Channel ID Set
[21:08:52] ANT : Radio Frequency set
[21:08:52] ANT : Opening channel 0
[21:08:52] ANT : Channel opened
[21:08:53] BLE : Starting Native BLE search
[21:08:53] ANT : Stopping ANT search (mfg network 1)
[21:08:53] ANT : Closed channel 0
[21:08:53] ANT : Channel 0 Closed
[21:08:53] ANT : Unassign Channel
[21:08:53] ANT : Unassigned Channel
[21:08:53] ANT : Starting ANT search (mfg network 2)
[21:08:53] ANT : Channel Assigned
[21:08:53] ANT : Setting Channel ID for chan 0 (device 00)…
[21:08:53] ANT : Unknown response
[21:08:53] ANT : Channel ID Set
[21:08:53] ANT : Radio Frequency set
[21:08:53] ANT : Opening channel 0
[21:08:53] ANT : Channel opened
[21:08:55] ANT : Stopping ANT search (mfg network 2)
[21:08:55] ANT : Closed channel 0
[21:08:55] ANT : Channel 0 Closed
[21:08:55] ANT : Unassign Channel
[21:08:55] ANT : Unassigned Channel
[21:08:55] ANT : Starting ANT search (mfg network 0)
[21:08:55] ANT : Channel Assigned
[21:08:55] ANT : Setting Channel ID for chan 0 (device 00)…
[21:08:55] ANT : Unknown response
[21:08:55] ANT : Channel ID Set
[21:08:55] ANT : Radio Frequency set
[21:08:55] ANT : Opening channel 0
[21:08:55] ANT : Channel opened
[21:08:55] FPS 16, 266639, 11608, -51251
[21:08:55] BLE : Starting Native BLE search
[21:08:56] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:08:57] ANT : Stopping ANT search (mfg network 0)
[21:08:57] ANT : Closed channel 0
[21:08:57] ANT : Channel 0 Closed
[21:08:57] ANT : Unassign Channel
[21:08:57] ANT : Unassigned Channel
[21:08:57] ANT : Starting ANT search (mfg network 1)
[21:08:57] ANT : Channel Assigned
[21:08:57] ANT : Setting Channel ID for chan 0 (device 00)…
[21:08:57] ANT : Unknown response
[21:08:57] ANT : Channel ID Set
[21:08:57] ANT : Radio Frequency set
[21:08:57] ANT : Opening channel 0
[21:08:57] ANT : Channel opened
[21:08:58] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:08:58] BLE : Starting Native BLE search
[21:08:58] ANT : Rx Fail on channel 3
[21:08:59] ANT : Stopping ANT search (mfg network 1)
[21:08:59] ANT : Closed channel 0
[21:08:59] ANT : Channel 0 Closed
[21:08:59] ANT : Unassign Channel
[21:08:59] ANT : Unassigned Channel
[21:08:59] ANT : Starting ANT search (mfg network 2)
[21:08:59] ANT : Channel Assigned
[21:08:59] ANT : Setting Channel ID for chan 0 (device 00)…
[21:08:59] ANT : Unknown response
[21:08:59] ANT : Channel ID Set
[21:08:59] ANT : Radio Frequency set
[21:08:59] ANT : Opening channel 0
[21:08:59] ANT : Channel opened
[21:08:59] NETCLIENT:[INFO] World clock offset updated from +21947346ms to +21947346ms (+0ms)
[21:09:00] ANT : Stopping ANT search (mfg network 2)
[21:09:00] ANT : Closed channel 0
[21:09:00] ANT : Channel 0 Closed
[21:09:00] ANT : Unassign Channel
[21:09:00] ANT : Unassigned Channel
[21:09:00] ANT : Starting ANT search (mfg network 0)
[21:09:00] ANT : Channel Assigned
[21:09:00] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:00] BLE : Starting Native BLE search
[21:09:00] ANT : Unknown response
[21:09:00] ANT : Channel ID Set
[21:09:00] ANT : Radio Frequency set
[21:09:00] ANT : Opening channel 0
[21:09:00] ANT : Channel opened
[21:09:02] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:09:03] ANT : Stopping ANT search (mfg network 0)
[21:09:03] BLE : Starting Native BLE search
[21:09:03] ANT : Closed channel 0
[21:09:03] ANT : Channel 0 Closed
[21:09:03] ANT : Unassign Channel
[21:09:03] ANT : Unassigned Channel
[21:09:03] ANT : Starting ANT search (mfg network 1)
[21:09:03] ANT : Channel Assigned
[21:09:03] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:03] ANT : Unknown response
[21:09:03] ANT : Channel ID Set
[21:09:03] ANT : Radio Frequency set
[21:09:03] ANT : Opening channel 0
[21:09:03] ANT : Channel opened
[21:09:03] FPS 15, 266639, 11608, -51251
[21:09:04] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:09:04] Broadcasting PR for segment -9223372031502377618 with time 61.46
[21:09:04] ANT : Stopping ANT search (mfg network 1)
[21:09:04] ANT : Closed channel 0
[21:09:04] ANT : Channel 0 Closed
[21:09:04] ANT : Unassign Channel
[21:09:04] ANT : Unassigned Channel
[21:09:04] ANT : Starting ANT search (mfg network 2)
[21:09:04] ANT : Channel Assigned
[21:09:04] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:04] ANT : Unknown response
[21:09:04] ANT : Channel ID Set
[21:09:04] ANT : Radio Frequency set
[21:09:04] ANT : Opening channel 0
[21:09:04] ANT : Channel opened
[21:09:05] ANT : Rx Fail on channel 2
[21:09:06] BLE : Starting Native BLE search
[21:09:06] ANT : Rx Fail on channel 1
[21:09:06] ANT : Stopping ANT search (mfg network 2)
[21:09:06] ANT : Closed channel 0
[21:09:06] ANT : Channel 0 Closed
[21:09:06] ANT : Unassign Channel
[21:09:06] ANT : Unassigned Channel
[21:09:06] ANT : Starting ANT search (mfg network 0)
[21:09:06] ANT : Channel Assigned
[21:09:06] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:06] ANT : Unknown response
[21:09:06] ANT : Channel ID Set
[21:09:06] ANT : Radio Frequency set
[21:09:06] ANT : Opening channel 0
[21:09:06] ANT : Channel opened
[21:09:07] ANT : Rx Fail on channel 1
[21:09:08] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:09:08] BLE : Starting Native BLE search
[21:09:09] ANT : Stopping ANT search (mfg network 0)
[21:09:09] ANT : Closed channel 0
[21:09:09] ANT : Channel 0 Closed
[21:09:09] ANT : Unassign Channel
[21:09:09] ANT : Unassigned Channel
[21:09:09] ANT : Starting ANT search (mfg network 1)
[21:09:09] ANT : Channel Assigned
[21:09:09] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:09] ANT : Unknown response
[21:09:09] ANT : Channel ID Set
[21:09:09] ANT : Radio Frequency set
[21:09:09] ANT : Opening channel 0
[21:09:09] ANT : Channel opened
[21:09:09] ANT : Rx Fail on channel 1
[21:09:09] ANT : Rx Fail on channel 3
[21:09:10] ANT : Stopping ANT search (mfg network 1)
[21:09:10] ANT : Closed channel 0
[21:09:10] ANT : Channel 0 Closed
[21:09:10] ANT : Unassign Channel
[21:09:10] ANT : Unassigned Channel
[21:09:10] ANT : Starting ANT search (mfg network 2)
[21:09:10] ANT : Channel Assigned
[21:09:10] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:10] ANT : Unknown response
[21:09:10] ANT : Channel ID Set
[21:09:10] ANT : Radio Frequency set
[21:09:10] ANT : Opening channel 0
[21:09:10] ANT : Rx Fail on channel 1
[21:09:10] ANT : Channel opened
[21:09:11] BLE : Starting Native BLE search
[21:09:11] FPS 13, 266639, 11608, -51251
[21:09:11] ANT : Stopping ANT search (mfg network 2)
[21:09:11] ANT : Closed channel 0
[21:09:11] ANT : Channel 0 Closed
[21:09:11] ANT : Unassign Channel
[21:09:11] ANT : Unassigned Channel
[21:09:11] ANT : Starting ANT search (mfg network 0)
[21:09:11] ANT : Channel Assigned
[21:09:11] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:11] ANT : Unknown response
[21:09:11] ANT : Channel ID Set
[21:09:11] ANT : Radio Frequency set
[21:09:11] ANT : Opening channel 0
[21:09:11] ANT : Channel opened
[21:09:13] BLE : Starting Native BLE search
[21:09:13] ANT : Rx Fail on channel 1
[21:09:14] ANT : Stopping ANT search (mfg network 0)
[21:09:14] ANT : Closed channel 0
[21:09:14] ANT : Channel 0 Closed
[21:09:14] ANT : Unassign Channel
[21:09:14] ANT : Unassigned Channel
[21:09:14] ANT : Starting ANT search (mfg network 1)
[21:09:14] ANT : Channel Assigned
[21:09:14] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:14] ANT : Unknown response
[21:09:14] ANT : Channel ID Set
[21:09:14] ANT : Radio Frequency set
[21:09:14] ANT : Opening channel 0
[21:09:14] ANT : Channel opened
[21:09:14] ANT : Rx Fail on channel 3
[21:09:14] ANT : Rx Fail on channel 2
[21:09:15] ANT : Stopping ANT search (mfg network 1)
[21:09:15] ANT : Closed channel 0
[21:09:15] ANT : Channel 0 Closed
[21:09:15] ANT : Unassign Channel
[21:09:15] ANT : Unassigned Channel
[21:09:15] ANT : Starting ANT search (mfg network 2)
[21:09:15] ANT : Channel Assigned
[21:09:15] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:15] ANT : Unknown response
[21:09:15] ANT : Channel ID Set
[21:09:15] ANT : Radio Frequency set
[21:09:15] ANT : Opening channel 0
[21:09:15] ANT : Channel opened
[21:09:16] BLE : Starting Native BLE search
[21:09:17] ANT : Stopping ANT search (mfg network 2)
[21:09:17] ANT : Closed channel 0
[21:09:17] ANT : Channel 0 Closed
[21:09:17] ANT : Unassign Channel
[21:09:17] ANT : Unassigned Channel
[21:09:17] ANT : Starting ANT search (mfg network 0)
[21:09:17] ANT : Channel Assigned
[21:09:17] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:17] ANT : Unknown response
[21:09:17] ANT : Channel ID Set
[21:09:17] ANT : Radio Frequency set
[21:09:17] ANT : Opening channel 0
[21:09:17] ANT : Channel opened
[21:09:17] Registered segment 29 with hash id 1071372
[21:09:17] NETCLIENT:[INFO] World clock offset updated from +21947346ms to +21947342ms (-4ms)
[21:09:18] BLE : Starting Native BLE search
[21:09:19] FPS 18, 266639, 11608, -51251
[21:09:19] ANT : Stopping ANT search (mfg network 0)
[21:09:19] ANT : Closed channel 0
[21:09:19] ANT : Channel 0 Closed
[21:09:19] ANT : Unassign Channel
[21:09:19] ANT : Unassigned Channel
[21:09:19] ANT : Starting ANT search (mfg network 1)
[21:09:19] ANT : Channel Assigned
[21:09:19] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:19] ANT : Unknown response
[21:09:19] ANT : Channel ID Set
[21:09:19] ANT : Radio Frequency set
[21:09:19] ANT : Opening channel 0
[21:09:19] ANT : Channel opened
[21:09:21] BLE : Starting Native BLE search
[21:09:21] ANT : Stopping ANT search (mfg network 1)
[21:09:21] ANT : Closed channel 0
[21:09:21] ANT : Channel 0 Closed
[21:09:21] ANT : Unassign Channel
[21:09:21] ANT : Unassigned Channel
[21:09:21] ANT : Starting ANT search (mfg network 2)
[21:09:21] ANT : Channel Assigned
[21:09:21] ANT : Setting Channel ID for chan 0 (device 00)…
[21:09:21] ANT : Unknown response
[21:09:21] ANT : Channel ID Set
[21:09:21] ANT : Radio Frequency set
[21:09:21] ANT : Opening channel 0
[21:09:21] ANT : Channel opened
[21:09:21] Setting sport to CYCLING
[21:09:21] ANT : Stopping ANT search (mfg network 2)
[21:09:21] Device List:
[21:09:21] ========================================
[21:09:21] Cadence Device: Cadence 13134
[21:09:21] Heart Rate Device: HR Strap 446
[21:09:21] Speed Device: Speed 19226
[21:09:22] ANT : Rx Fail on channel 1
[21:09:24] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:09:26] ANT : Rx Fail on channel 2
[21:09:27] ANT : Rx Fail on channel 2
[21:09:27] ANT : Rx Fail on channel 1
[21:09:27] FPS 22, 266595, 11607, -51224
[21:09:28] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:09:28] Starting critical power curve search job (380489) mTimeStamp = 50.29190 m_lastSearchTime = 50.29190 calculating=false
[21:09:29] Registered segment 30 with hash id 1071413
[21:09:30] ANT : Rx Fail on channel 2
[21:09:33] ANT : Rx Fail on channel 3
[21:09:33] Setting activity local fit file name to 2020-05-21-21-08-04.fit
[21:09:34] Uploading activity to server – fit file name = C:\Users\atrevejo\Documents/Zwift/Activities/inProgressActivity.fit
[21:09:34] NETCLIENT:[INFO] Activity Upload: load fit file from path C:\Users\atrevejo\Documents/Zwift/Activities/inProgressActivity.fit
[21:09:34] NETCLIENT:[INFO] Activity Upload: fit file is length 807
[21:09:34] ANT : Rx Fail on channel 3
[21:09:35] FPS 18, 265132, 11581, -50516
[21:09:36] ANT : Rx Fail on channel 3
[21:09:38] ANT : Rx Fail on channel 1
[21:09:38] Starting critical power curve search job (390558) mTimeStamp = 60.37193 m_lastSearchTime = 60.37193 calculating=false
[21:09:39] ANT : Rx Fail on channel 3
[21:09:40] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:09:43] ANT : Rx Fail on channel 1
[21:09:43] Registered segment 31 with hash id 1008469
[21:09:43] FPS 18, 261567, 11456, -48292
[21:09:44] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:09:44] ANT : Rx Fail on channel 1
[21:09:45] ANT : Rx Fail on channel 3
[21:09:45] ANT : Rx Fail on channel 1
[21:09:47] NETCLIENT:[INFO] Sending telemetry…
[21:09:47] ANT : Rx Fail on channel 1
[21:09:47] NETCLIENT:[INFO] UDP metrics {StC Rx: 704, Rx error: 0, CtS Tx: 158, Tx error: 0}
[21:09:48] Starting critical power curve search job (400628) mTimeStamp = 70.41590 m_lastSearchTime = 70.41590 calculating=false
[21:09:48] ANT : Rx Fail on channel 1
[21:09:49] ANT : Rx Fail on channel 2
[21:09:50] ANT : Rx Fail on channel 1
[21:09:50] ANT : Rx Fail on channel 3
[21:09:51] FPS 24, 259287, 11396, -46747
[21:09:54] ANT : Rx Fail on channel 2
[21:09:56] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:09:58] Starting critical power curve search job (410708) mTimeStamp = 80.50988 m_lastSearchTime = 80.50988 calculating=false
[21:09:59] NETCLIENT:[INFO] World clock offset updated from +21947342ms to +21947340ms (-2ms)
[21:09:59] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:09:59] FPS 17, 257398, 11355, -45496
[21:10:01] ANT : Rx Fail on channel 3
[21:10:03] ANT : Rx Fail on channel 2
[21:10:06] ANT : Rx Fail on channel 3
[21:10:07] ANT : Rx Fail on channel 2
[21:10:07] FPS 24, 254988, 11311, -43932
[21:10:08] Starting critical power curve search job (420833) mTimeStamp = 90.62395 m_lastSearchTime = 90.62395 calculating=false
[21:10:11] ANT : Rx Fail on channel 2
[21:10:12] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:10:12] ANT : Rx Fail on channel 1
[21:10:15] ANT : Rx Fail on channel 1
[21:10:15] FPS 28, 252356, 11262, -42173
[21:10:16] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:10:17] ANT : Rx Fail on channel 2
[21:10:18] ANT : Rx Fail on channel 1
[21:10:18] Starting critical power curve search job (430893) mTimeStamp = 100.69001 m_lastSearchTime = 100.69001 calculating=false
[21:10:19] ANT : Rx Fail on channel 1
[21:10:20] ANT : Rx Fail on channel 3
[21:10:21] ANT : Rx Fail on channel 1
[21:10:21] ANT : Rx Fail on channel 2
[21:10:22] ANT : Rx Fail on channel 2
[21:10:22] ANT : Rx Fail on channel 1
[21:10:23] FPS 31, 247769, 11183, -39189
[21:10:24] ANT : Rx Fail on channel 1
[21:10:24] TimingArch: crossed arch start line SPRINT
[21:10:25] TimingArch: SPRINT wants to show timerR
[21:10:25] ANT : Rx Fail on channel 1
[21:10:26] ANT : Rx Fail on channel 2
[21:10:26] ANT : Rx Fail on channel 3
[21:10:28] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:10:28] TimingArch: (SPRINT) passed checkpoint 0
[21:10:29] Starting critical power curve search job (440956) mTimeStamp = 110.74096 m_lastSearchTime = 110.74096 calculating=false
[21:10:30] ANT : Rx Fail on channel 2
[21:10:31] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:10:31] FPS 15, 242354, 11093, -35590
[21:10:32] TimingArch: (SPRINT) passed checkpoint 1
[21:10:33] ANT : Rx Fail on channel 3
[21:10:36] TimingArch: (SPRINT) passed checkpoint 2
[21:10:38] ANT : Rx Fail on channel 2
[21:10:39] Starting critical power curve search job (451035) mTimeStamp = 120.80998 m_lastSearchTime = 120.80998 calculating=false
[21:10:39] TimingArch: (SPRINT) passed checkpoint 3
[21:10:40] FPS 17, 236134, 10992, -31464
[21:10:40] ANT : Rx Fail on channel 3
[21:10:40] ANT : Rx Fail on channel 2
[21:10:43] TimingArch: (SPRINT) passed checkpoint 4
[21:10:44] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:10:46] TimingArch: hit finish line for SPRINT
[21:10:46] TIMING ARCH: Player (male) passed finish line of segmnet -9223372031502377618 at time 176072176.00 in 21.92 seconds (avg watts 145.98).
[21:10:46] Got Notable Moment: SET A TIME
[21:10:46] LEADERBOARDS: Saving segment results for segment -9223372031502377618 with a time of 176072176.00
[21:10:46] Broadcasting PR for segment -9223372031502377618 with time 21.92
[21:10:47] NETCLIENT:[INFO] Sending telemetry…
[21:10:47] NETCLIENT:[INFO] UDP metrics {StC Rx: 836, Rx error: 0, CtS Tx: 305, Tx error: 0}
[21:10:48] FPS 16, 230129, 10897, -27403
[21:10:48] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:10:48] ANT : Rx Fail on channel 2
[21:10:49] NETCLIENT:[INFO] World clock offset updated from +21947340ms to +21947340ms (+0ms)
[21:10:49] Starting critical power curve search job (461132) mTimeStamp = 130.90593 m_lastSearchTime = 130.90593 calculating=false
[21:10:50] Registered segment 32 with hash id 1071398
[21:10:53] FB resize: 0 x 0
[21:10:53] resize: 1 x 1
[21:10:55] ANT : Rx Fail on channel 1
[21:10:55] ANT : Rx Fail on channel 2
[21:10:56] FPS 63, 224648, 10819, -23854
[21:10:58] ANT : Rx Fail on channel 1
[21:10:59] Starting critical power curve search job (471165) mTimeStamp = 140.98326 m_lastSearchTime = 140.98326 calculating=false
[21:10:59] ANT : Rx Fail on channel 2
[21:10:59] ANT : Rx Fail on channel 1
[21:11:00] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:11:00] ANT : Rx Fail on channel 2
[21:11:00] Registered segment 33 with hash id 1008855
[21:11:00] ANT : Rx Fail on channel 3
[21:11:03] ANT : Rx Fail on channel 2
[21:11:04] FPS 34, 220582, 10762, -21165
[21:11:04] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:11:07] ANT : Rx Fail on channel 2
[21:11:09] Starting critical power curve search job (481205) mTimeStamp = 151.04008 m_lastSearchTime = 151.04008 calculating=false
[21:11:09] Registered segment 34 with hash id 1071410
[21:11:12] FPS 37, 219637, 10749, -20509
[21:11:14] ANT : Rx Fail on channel 3
[21:11:16] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:11:16] ANT : Rx Fail on channel 2
[21:11:18] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión.’ (10061)
[21:11:19] Starting critical power curve search job (491232) mTimeStamp = 161.06293 m_lastSearchTime = 161.06293 calculating=false
[21:11:20] FPS 43, 219644, 10750, -20500
[21:11:20] ANT : Rx Fail on channel 2
[21:11:21] ANT : Rx Fail on channel 2
[21:11:22] ANT : Rx Fail on channel 2
[21:11:23] ANT : Rx Fail on channel 3
[21:11:25] ANT : Rx Fail on channel 2
[21:11:28] FPS 45, 219666, 10750, -20466
[21:11:29] ANT : Rx Fail on channel 1
[21:11:29] Starting critical power curve search job (501326) mTimeStamp = 171.12979 m_lastSearchTime = 171.12979 calculating=false
[21:11:29] ANT : Rx Fail on channel 2
[21:11:30] ANT : Rx Fail on channel 1
[21:11:32] ANT : Rx Fail on channel 1
[21:11:32] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:11:32] NETCLIENT:[INFO] Auxiliary Controller connected successfully
[21:11:32] NETCLIENT:[WARN] Discarding command from phone: 29
[21:11:32] NETCLIENT:[INFO] Sending Pairing Status of: true
[21:11:33] LIVESEG: Sending Active Segments.
[21:11:35] ANT : Rx Fail on channel 1
[21:11:35] ANT : Rx Fail on channel 3
[21:11:35] Registered segment 35 with hash id 1092830
[21:11:36] FPS 36, 219688, 10750, -20433
[21:11:39] Starting critical power curve search job (511354) mTimeStamp = 181.18553 m_lastSearchTime = 181.18553 calculating=false
[21:11:40] ANT : Rx Fail on channel 2
[21:11:41] ANT : Rx Fail on channel 3
[21:11:44] ANT : Rx Fail on channel 2
[21:11:44] FPS 39, 219710, 10750, -20399
[21:11:47] NETCLIENT:[INFO] Sending telemetry…
[21:11:47] NETCLIENT:[INFO] UDP metrics {StC Rx: 737, Rx error: 0, CtS Tx: 157, Tx error: 0}
[21:11:48] ANT : Rx Fail on channel 2
[21:11:49] Starting critical power curve search job (521386) mTimeStamp = 191.21931 m_lastSearchTime = 191.21931 calculating=false
[21:11:52] FPS 43, 219732, 10750, -20365
[21:11:57] ANT : Rx Fail on channel 3
[21:11:58] ANT : Rx Fail on channel 2
[21:11:59] Starting critical power curve search job (531416) mTimeStamp = 201.24312 m_lastSearchTime = 201.24312 calculating=false
[21:12:00] FPS 34, 219754, 10750, -20332
[21:12:01] ANT : Rx Fail on channel 3
[21:12:02] ANT : Rx Fail on channel 2
[21:12:05] NETCLIENT:[ERROR] Auxiliary Controller received ‘Se agotó el tiempo de espera del semáforo.’ (121) during message length receive handler
[21:12:05] NETCLIENT:[INFO] Auxiliary Controller shutting down keep alive loop
[21:12:05] ANT : Rx Fail on channel 1
[21:12:06] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.0.19:21587
[21:12:06] NETCLIENT:[INFO] Auxiliary Controller connected successfully
[21:12:06] NETCLIENT:[WARN] Discarding command from phone: 29
[21:12:06] NETCLIENT:[INFO] Sending Pairing Status of: true
[21:12:06] ANT : Rx Fail on channel 2
[21:12:07] LIVESEG: Sending Active Segments.
[21:12:07] ANT : Rx Fail on channel 1
[21:12:08] FPS 32, 219776, 10750, -20298
[21:12:09] Starting critical power curve search job (541483) mTimeStamp = 211.28290 m_lastSearchTime = 211.28290 calculating=false
