Amazon Fire Tv (4k)
Has anyone tried to get Zwift running on a Fire Tv (Gen 2 4k)? I tried last night using the method described on these forums for the Nvidia Shield but i couldn’t get past a warning message about [INSTALL FAILED OLDER SDK] which i am guessing is because the FireTV runs a really old semi verison of Android.
Has anyone had a play? Or is the hardware simply not upto the job? Its listed as having a MediaTek 8173C CPU and PowerVR Rogue GX6250 GPU.
Same here, fireTV 4kG2 is a no go. Hardware seems ok to run the app. Must keep trying…
Did you try the method from this website techowns,com zwift-on-firestick
