Zwift Play connection not working Windows 10
I have the latest firmware for Zwift Play controllers and Zwift is up to date. I have had intermittent connection problems with the Play controllers, but when unable to pair I have used “Connect through phone”.
Today, this also caused problems as I had several power drop outs and I had to leave the race, reconnect power source and rejoin without working Play controllers.
Are there any plans to fix the connection issue for the Zwift Play controllers? Unless, I fear that the Play controllers was just a waste of money.
I don’t have any connection problems with mine, also in windows 10.
Are you using a bluetooth dongle on a USB extension cord so it is right under your bike?
try plugging them in to power while using them.
i have frequent drop outs but when i plug them in to power i have no issues.
Thanks Chris. This actually worked.
Next question. Will the connection issue be fixed so that I don’t have to have the controllers connected to a powersource while using them?
Yeah, not sure why it works but it does seem to fix the issue.
