When I try to log in, after I enter the password, it says “check internet connection” which I did and it was fine. I then restarted the computer and no difference. I also turned off firewall.
The password is correct as I logged in to post this .Has this ever happened to anyone?
Thanks in advance.
Hi Brian,
Please submit a support ticket and we’ll look into it.
Thanks!
Hello Brian!
Have your problem solved yet? Did you figured out what caused the “check internet connection” problem?
I am in the same situation right now.
