Question 1: is CE still be iterated or is this the final version as a ranking system is being worked on?
I guess if this is it all the other question are irrelevant.
I guess the answer is it depends. If it’s something we can change or fix without a significant amount of effort, we will. If not, we prioritize the ranking system.
Question 2: if its still being worked on would it be better that zFTP is calculated using 30s, 5m, 8m and 10m max as these are the factors that win a Zwift race, hardly anyone targeted with CE (to move up) will ever do a max 20 min effort let alone 30-40 minutes. Including these Z2 efforts just drags it down?
Once again this is a wrong assumption. Just because I gave that example above of the power tests, it doesn’t mean that ONLY those durations impact zFTP. Those are like the baseline test to establish the power profile. Also, CE is not dependent only on zFTP. Just like you mentioned about the short duration efforts, that’s why we use the other metric zMAP to give us an estimate of the Zwifter’s capability in short duration efforts within the 3 to 6 min. range.
Question 3: Looking at the facebook pages FTP vs zFTP is causing confusion and there are riders below, equal and above their FTP and not sure which is correct, both as they are calculated differently. As this metric is being used for CE why not call zCE as that’s what it really relates to and it’s not a training number? I’m sure now it’s out there you don’t want to change it, but with clear messaging it wouldn’t be so bad.
Maybe we introduced confusion to some folks with the FTP vs. zFTP debate. Like I said multiple times, we introduced the term simply because of consistency with other softwares that use the same kind of notation. We will try to put out some documentation explaining the differences and “educate” the community. I think coming up with some random terms also won’t help.
Besides metrics like zFTP that we are calculating in the background were not created solely for CE.
To be honest, and to be scientifically correct, I wanted to introduce zFTP as a zone and not as a single number, because the experts out there should know that FTP is more of a zone and not a single number where everything changes. That would be even more shocking, and therefore was not done that way. So for me discussing if zFTP=250w and eFTP=253w which one is correct, etc. etc… is just a waste of time. In case the differences are larger, clearly one of them doesn’t have the best data.
But like I said, we hope to put out documentation to help settle down these debates.
