PD4.1 causes odd RoboPacer behavior [KNOWN ISSUE - FIX PENDING]
Here is Jacques on 3 sister route on PD4.0. Like other has said. There are updates/changes that others have noticed to PD4.1. If you look above this is the same watts needed to stay with Yumi on PD4.1. I don’t think coasting for 6 min is going to cost me 10 watts over a 3 hour ride, maybe an hour ride…
Which of those two do you think best approximates the power required to do that same ride outdoors in a real life situation?
None really. What bothers me the most is getting pushed off my line when I’m drafting someone. Plus when do you pass other on the inside of a group, never. You always rotate on the left. Zwift isn’t really like outdoors when you get down to the details of it…
Finally got to try a robo pacer with 4.1 yesterday. I spent 90 mins with Yumi on Tick Tock, and I had a prior 90min ride with Yumi on Tick Tock from April that I could compare it to.
I know this is not a hilly route, so there was not a lot of dynamic pacing in it, but perhaps it’s interesting for people to see how PD4.1 compared on a ride in April with limited climbing as one data point.
This is from my inervals.icu data.
Ride with PD 4.1: Yumi on Tick Tock (8/28/2023)
  • Total time: 1h30m28s
  • Normalized power: 216W
  • Average power: 215W
  • Time above Tempo (264W+): 1s
  • Time in Tempo (221W-264W): 36m8s
  • Time in Endurance(162W-220W): 53m42s
  • Time in Recovery (0-161W): 37s
Ride prior to PD4.1: Yumi on Tick Tock (4/26/2023)
  • Total time: 1h30m42s
  • Normalized: 215W
  • Average: 214W
  • Time above Tempo (265W+): 0s
  • Time in Tempo (221W-264W): 27m25s
  • Time in Endurance (162W-220W): 1h1m
  • Time in Recovery (0-161W) 36s
I’m not sure when PD4.0 was released, so not sure what version of pack dynamics we were using in April. Overall power, and normalized power were pretty much the same for me on this flat route between both these scenarios.
My goal with the pacer rides is to stick right behind the pacer, trying to minimize large power fluctuations where possible, and it did seem overall it was easier to fall back quickly than it was to come back to where the pacer is with 4.1 (which is why I ‘think’ there was more time in tempo - but very low tempo given the averages are so close), I presume on average people behind the pacer are increasing their power a tiny bit to ensure they don’t fall out of the drops window, so I think that would be the reason.
I did another ride with RP and i still haven’t witness any odd behavior.
1 hour / 1 Lap with Coco on Three Little Sisters and i averaged 188W or 2,35W/kg with plenty of coasting down Volcano KOM.
I teleported to Genie that is on Watopia Waistband and i only averaged 216W or 2,7W/kg for 30mins…doing 1W/kg less than RP.
I have also witnessed this strange behaviour since the release of PD 4.1 it’s like there is an invisible wall that stops you moving forward unless you increase watts by a substantial amount.
Tonight I did a warmup with Yumi on Tick Tock in Watopia my average power was 178 watts 3.2 w/kg which is way higher than normal as this is my Zone 2 and I usually choose Genie to achieve similar power.
I had a theory that staying ahead of the pace partner would be easier, so I tried that with Yumi today. Instead of hanging behind Yumi I kept in front, and put extra effort into surging to keep in front of Yumi (which is different than what I have done in the past). I tried my best not to jump into the wind out front, so tried to hold back from the very front to make sure I wasn’t pushing the pace personally.
These were my stats which you can compare with my last post a few posts back (data from intervals.icu):
Yumi on Tick Tock - PD4.1 but staying ahead of pacer (4/29/2023)
  • Total time: 1h30m33s
  • Normalized Power: 221W
  • Average Power: 219W
  • Time Above Tempo (264W+):1m49s
  • Time in Tempo (221W-264W):41m27s
  • Time in Endurance (162W-220W): 46m34s
  • Time in Recovery (0-161W): 43s
So, for me pushing to stay ahead of Yumi was actually harder than letting myself float behind. My theory is the draft was less up closer to the front even though I wasn’t leading the group, and all the spikes in power to get back ahead of Yumi when they went ahead eventually added up.
I did notice once at the bottom of one short hill on Tick Tock in the tunnel it seemed Yumi shot ahead of everyone pretty easily. My theory is that’s when they spiked power from the bottom of the hill transitioning to flat due to dynamic pacing and the new 4.1 dynamics thought they were attempting to surge ahead of the pack while everyone else was trying to maintain a more constant pace, or perhaps most people were lagged in terms of when they hit higher power at the bottom of the hill. Not sure. But Yumi seemed to move up quickly at that point.
This is my ride from this morning with Coco on 3 sisters. I’m 81.5kg. All zone 2 or 1 on the flats. Just staying with her since this is a recovery week for me. How much difference there is…hmmmm
The “invisible wall” is supposed to happen. PD4.1 seems to simulate a bit better the IRL phenomenon of not being able to ride through another person, so it blocks you from being able to do that unless you are strongly pushing past. From my view, it seems like those who are getting higher watts with the same pacer after 4.1 are just pushing harder than they need to? IRL you wouldn’t, but it’s hard to tell in-game.
Are you sure? Zwift Insider’s tests seem to confirm that watts saved is still higher farther back. Maybe there was another factor? I’m not sure, just surprised. If it is harder inside the group than the front row, something definitely isn’t right (like the CdA bonus is too strong for those in low-draft situations). But surely the idea of pack being easier than front row is still there?
This said, I feel the need to do a PD4.1 race so I can try and pass people more, as most of my group riding has been easy days with Bernie and Miguel.
For me this is not about whether the draft is stronger nearer the front or back of a pack, or how realistic the dynamics are.
I am only comparing 4.1 with 4, and my experience is that it is now relatively harder to maintain the front middle position and I drift backwards more easily. Then if I want to push back towards the front, it takes way more effort under 4.1 than 4. Again only comparing the two, and the current system causes me to waste considerable effort vs PD4. Some have said that it’s just a question of learning and adapting to the new dynamics. But if I want to move forward in the pack, I don’t see how else I can move up without this much greater level of wkg than previously? Is there a technique or timing I should be aware of?
I might well use less effort simply staying towards the back of a pack, but if I want to move up, 4.1 is extremely “sticky” vs 4. Plus the increased tendency to drift backwards only encourages me to work harder from the back to avoid being dropped completely.
Also, as a lighter rider than the RP, I know that in general I can best make up ground going uphill. However the RPs now frequently burst forward at the bottom of an incline (no idea why more so now than before), so quite often I only manage to “catch up” towards the top of an incline, and it’s now (relatively) much harder to maintain an efficient position both downhill and on the flats.
Yeah, I think you’re correct based on my last couple of rides with pace partners. It does seem pretty easy to fall back even if you’re trying to hold a consistent wattage (if people around you are trying to move up for instance and if they are willing to vary power more than you are), and then moving back up to the pace partner yourself does seem to make you work harder than before. You’re a bit more sticky moving up, but not much more sticky moving back I guess.
So, if for instance you’re desire is to keep with the pace partner it does seem that it’s not super easy to do so without larger variations in power to what you needed before. But maybe I’ve not learned how to do it better yet.
I think if you are ok with hanging at the back, it works, but if you start getting the “you’re too far back” notification for the pace partner then you don’t have much option but to push harder to move up positions, and likely everyone around you at that point (who are also getting that same message) will be trying to do the same thing.
NOTE:
For Zwift to recognise this thread and therefore read and act upon it you need to VOTE at the top of the thread. Make sure you do this otherwise we may as well be talking to a brick wall…
See screenshot for location of the vote button (Click on Vote not the number)
could anyone from zwift check if the bots are running the same version of the app as the rest of the users, please? we’ve had similar issues before (here and here). previously @DavidP and @James managed to fix this problem.
in the meantime, here’s my ride with constance this morning:
and here are three rides from the past for comparison:
overall there’s 20-30 watts difference.
lastly, here are two screenshots from today’s ride:
downhill, -4% and i need to do 4wkg to keep up:
flat, 1% and i need to do the same watts as the bot… as if there was no draft:
IT Was FIxed…i reported this more than 2 Weeks Ago and that was a problem in MAKURI while testing PD4.1
last saturday i did a 200km ride with constance on watopia’s waistband and averaged 250 watts over 5 hours. this week, since the rotation on monday, i’m struggling to keep up for more than 1 hour… maybe something changed in the meantime and i guess it wouldn’t hurt anyone to check…
I see your pictures are from Makuri…did you try to ride with Constance in Watopia this week? In Makuri on some surfaces you will need to put almost the same power as RP to keep up.
that is not true. the surface is different in places, but the overall average is more or less the same. check my other rides, i posted screenshots from strava in my previous message.
and just for the record, yes, i did a 100k ride on the flat route in watopia yesterday and it was a disaster. the feedback is the same from everyone i’m riding with - the effort increased significantly.
I did a ride yesterday with Coco and Genie as reported above you can see my stream
Genie is 3.7Wkg on Watopia Waistband and i did 2.72Wkg
and Coco is 2.4Wkg on Three Little Sisters and i did 2.35Wkg
That is what @Eric-Schlange-ZI described as Wasted Watts in his article when testing new PD4.1
I am really enjoying PD 4.1. I am enjoying learning the slight differences and the new feeling.
I am sure that those who are struggling just need more time to ‘learn’ the new dynamics. :+1:
Here is my thinking:
Previously (with 4.0), as a very simple example, doing the same power as the person in-front would see you catch and roll past that person… this ‘free speed’ would give you the feeling that you could ease. Now without the ‘free speed’, you think you have to keep pushing, but you can ease more than you think. PD 4.1 is not broken, it is just a new feeling to learn.
Everyone adapted to 4.0, now with 4.1, we have to adapt (our brains) to not getting the signals of ‘free speed’ through the pack, and wasting watts by pushing more than needed.
The challenge is to back off as much as possible to ‘learn’ the new feeling of holding position.
As people are still adapting, RoboPacer rides with big bunches (I think) can be more challenging at the moment - with everyone pushing (when they don’t need to), it will have a knock on effect.
To me, when riding in a small bunch or solo with a RoboPacer, the same level of draft is still possible.
Yes, it is now more of an effort to move through the pack. Personally, I think that is fine, and again, that is something we can learn and is a style that we can adapt to.
As a lightweight rider, Downhill’s are so much nicer with PD 4.1 aswell (mainly due to the slower pack speeds from less of the churning on the front).
Keep experimenting. Keep learning. PD 4.1 will feel ‘normal’ very soon! :slightly_smiling_face:
Thank you for your post @Jon_Wakefield . I was trying to keep out of the discussion to see where it would lead, but I guess you and @DejanPresen have helped give some “validation” into what is the problem and solution :+1:
