Just wondering what the general consensus is on the accuracy of Zwifts algorithm in terms of rider height vs speed?
I train with a friend both on Zwift and on roads, when we are out and about he destroys me, but when we are on Zwift I am able to drop him, so something doesn’t seem right.
We are both using calibrated smart trainers with our real height/weight numbers, so I don’t think there is a problem with our equipment or setups.
I have noticed that a lot of A/B category riders seem to be a specific height/weight, there do seem to be an abundance of riders around the 170cm / 70kg mark, but that may just be to do with the distribution curve of the population in general more than anything else.
Still, there are definitely a few youtube videos around, which seem to suggest than changing a rider’s height in their Zwift profile has a HUGE impact on ride time of say a 1 hour ride, with taller riders taking several mintues longer than shorter riders (with all other stats equalised).
Any tall riders out there who train with shorter guys having similar issues…?
I don’t have any direct comparisons like you do, but I don’t think generally that being tall (I’m 193cm) in the real world affects you as much as Zwift seems to think it does. Perhaps if you’re sitting completely up right, but when do we do that?
Zwift makes simple assumptions about aerodynamics from height and weight.
But look at a photo of yourself on a bike. Then look up a pro with the same height and look at a photo of them on a bike. I’m guessing you’ll observe the following:
their back is a lot flatter
their clothing fits a lot tighter
These two factors alone are huge in aerodynamics. Yet Zwift will treat you the same as the pro (perhaps wider if your BMI isn’t at the pro level).
Additionally, not everyone is as good at riding trainers. Outdoors, the bike moves back and forth when we apply lateral forces. On most trainers, the bike simply pushes back. So the pedal dynamics are different. Different riders experience different amounts of power loss going from outdoors to indoors. Maybe some have more power indoors if they only ride indoors.
Then there’s the environment. Consider you’re riding at 200 watts, which is low power. But this means your body is producing 200 watts, but internally dissipating around 640 watts, assuming 24% metabolic efficiency. That’s a lot of heat being generated in the room (840 watts total). So unless you have adequate airflow, it’s easy to overheat, and that leads to cardiac drift, and that causes power to drop. Outdoors this is far less an issue.
So the model is good, but it’s very simple. Maybe a future generation Zwift will have a camera filming your position as you ride, checking the fit of your clothing, and using image processing to send CdA numbers to the game. But it’s not there yet.
There’s a video on-line of Alex Dawsett riding a time trial on Zwift – he’s one of the top time trialists in the world among pros. Yet he got beaten on Zwift, because part of his success is his aero positions. Zwift doesn’t know anything about that – it just assumes an average for his height and mass.
I’m trialling another cycling app and in it you can change your cdA which might sound like a good idea but then everyone would just put that at the minimum.
For apps which mimic real-life, like one which uses videos of actual climbs that I might also climb IRL and I want to compare times, it makes sense to allow a user to adjust CdA to better reproduce reality, for example “time trial position”, “road race position”, “recreational/climbing position” (even pros sometimes have their jersey hanging open on climbs, for example), as deviations from a baseline formula based on height and BMI. But Zwift isn’t so devoted to modeling real life. So it makes sense Zwift would use an optimistic number.
I’m 205cm, 90kg, have an FTP of 350 and I get dropped by people doing 100w less than me on Zwift. But out in the real world I hold many longer flat segment KOMs (in metro area).
So yeah, Zwift unfairly penalized tall riders. I expect to be bad at the climbs, but I also expect to be great at the flats. In Zwift I’m bad at everything…
I’ve noticed that when riding the same bike IRL vs Zwift (OK, I could never afford the Zipp 808:s IRL), I get about 4-5 km/h more average speed in Zwift so I assume that the Zwift algorithm assumes quite an aerodynamic position. At least something I can’t hold for 2-3h straight.
Another thing is probably there there is no wind in Zwift. Outdoors, head/tail winds pretty much cancel out but sidewinds sucks power from both directions. I also have the feeling that my stroke is more “well-rounded” in Zwift, that would probably eliminate more of the micro-accelerations/decelerations and give some advantage(?)
As somebody weighing in at 86kg and living in a flat area I wonder what kind of strange fetish cyclists have with climbs?!
Yes, there are significant differences between Zwift and real life. I do not think Zwift is really intended to be a realistic simulation of reality. I treat Zwift as a game with advantages (no cars, lots of people to ride with,…) and disadvantages (no road feel, not the warmth of the sun on your body,…).
Having a realistic simulation would be nice, but that would put the bar of entry higher. Want to experience real gradients? Want to feel the head wind? Be able to steer?
Your remark on stroke execution is something I can relate to. Because there is not a lot else to distract you it is easier to focus on a fluid motion. Especially when doing a work out in ERG mode with a target cadence.
