Indoor compared to outdoor
New to zwift.
I have been using zwift for about a month now. Mostly workouts just to following a training plan.
When I finish my zwift ride the distances are incredible low. For what I am aware of is that watt per kg (weighing in at 100kgs) has and ERG can have effect but outside can door much more.
For instance, last north did a workout for climbing g and only completed 4.5mm where as last week outdoor did 46km in 110 mins at a steady easy pace.
is there something I can do, I am dropping weight.
Any help much appreciated
James
If you’re the Welsh JJ, the reason you’re not covering much ground is because you’re climbing up the virtual Mont Ventoux!
If you did that in real life you’d not do many km either!
:+1:
Do the same workout on the Tempus Fugit route and report back on your progress :+1:
Virtual distance does not translate well to IRL. Measure time and estimated calories.
100kg in Zwift is hard work, unfortunately its not geared towards actual real world road cycling.
You also need to stick to mainly flat routes with minimum total elevation gains.
This depends on what route you selected for the workout. You just have to keep at it and gradually build the hours of riding up. The more you ride, you’ll slowly start dropping weight. The next step is doing rides appropriate to your level of fatigue. As you build more power, you’ll see the effect of that as well.
I find that Zwift gives much more kms for the same effort because you don’t have to slow down for corners, you can just ride through other people, etc. In real life you have slow corners, bad road surfaces slowing you down, other people (cars, riders, pedestrians) doing unexpected things. It all adds up to making you slower.
An old friend of mine would say 100kg is hard work outside too, he struggled at first and I can certainly confirm, I was riding with him as a sort of lanterne rouge rider helping to encourage him along.
Struggled due to pure weight or fitness level ? I’m talking the difference between a fully trained riders.
Struggling at first would tend to indicate a pure weight/fitness issue of course he will have problems.
