I noticed that on the “Four by Four” race series, the “TT Club” events are organized by categories A-D (based on W/kg), but the other event types are organized by Racing Score.
Is that expected? I haven’t done a lot of TT events, but I have a TT bike I’d like to put in the miles to upgrade.
I just found the difference in race organization surprising.
James Bailey wisely stopped using ZRS for Zwift TTs some time ago, reverting to Category Enforcement, used for a majority of races Feb '22 until summer '24.
CE isn’t perfect, but it’s heck of a lot better than any incarnation of ZRS we’ve had for almost two years.
Speed on zwift scales much closer to w/kg than watts, even on the flat. CdA is calculated using height and weight, so heavier people are less aerodynamic.
Unfortunately zwift doesn’t have any native categorisation options that line up with their physics model.
Thanks for posting the quote.Using zFTP (in watts) makes sense for a TT event.
That leaves open the question of why the Four by Four TT events are categorized by W/kg, instead of zFTP.
The Event form says Cat D is 1.0 to 2.5 W/kg. If the quote from James is accurate, that should be zFTP instead. Or the text in the Event entries is wrong.
I can clarify that. The event is using Pace Group Category Enforcement, which puts you in a category based on W/kg for zMAP (around 5-6 minute power) or zFTP (often around 40 minute power) based on the thresholds in this document:
So the D category riders will have both zMAP no more than 3.2W/kg, and zFTP no more than 2.63W/kg.
Well categories used to be simpler but less fair. Even the complexity doesn’t eliminate the unfairness but hopefully produces groups with a tighter range of ability. Here on the forum you can find people who basically live down the rabbit hole of how that stuff works. But there’s no requirement to be some kind of deviant who thinks about racing categories all the time - you can also just do the races, and hopefully enjoy them.
Categorisation is pointless for iTTs imho. The only place they make sense is where the TT is part of a series (as categorisation DOES make sense in scratch/points races).
What does it matter if you win your category? If its w/kg it just means you’re heavy, and if its ZRS it means you’ve not done many races or are a poor scratch racer…
I’d rather the default for every event was a mass start with a filter at the end for velo/age. There is always someone faster than you, and that is ok. If race attendance was getting too large start splitting, but most of the time it’s 1-10 people per cat.
