Hi. I’m a relatively new cyclist and Zwifter. Im using and Elite Qubo Power B+ Smart turbo and I’m not sure if it’s putting out the correct power output. I’m fairly fit (triathlon) yet when it got up to 150watts on Alp Du Zwift, I almost couldn’t push the pedal down (I’m 60kg). On the lowest gear, I was putting out 120watts but couldn’t get above 70rpm. I could be rubbish at hills, but is there any way I can check? Guidance on this turbo / subject is quite complex for a newbie (P1, 2 and 3 values!?) so simple is good. Thanks.
Related topics
Topic | Replies | Views | Activity | |
Elite Qubo Digital SmartB+_Very low w/kg | 7 | 3071 | April 6, 2020 | |
Elite qubo Digital smart B+ averaging 40 watts 0.4 w/kg. Advice needed. Thank you | 2 | 1433 | February 20, 2019 | |
Zwift Elite Qubo elite digital smart B+ | 6 | 837 | October 22, 2017 | |
Elite Qubo Power Fluid Wattage Numbers | 12 | 6445 | December 5, 2017 | |
Elite Turbo Muin power output comparisment | 1 | 776 | October 25, 2016 |
