Does this combination work for Zwift
Hi All,
I am very new to Zwift and want to use it.
If I buy a normal stationary bike like SOSUDA one (around $350) which is not smarter training bike, then I use [Wahoo RPM Cycling Cadence Sensor, Bluetooth/ANT+ ]. In this case, can I use Zwift ?
thank you all for your reply.
Hi @Kevin_Yan
Welcome to the forum.
No, Zwift does not have a power curve for a stationary bike.
You will need a power meter…easiest is to get pedal power meter: Powertap, Garmin, SRM, Assioma…
But you will have to manually adjust the resistance.
The whole point is to get a smart trainer and have Zwift (or other apps) control the resistance of the bike.
Check this out @Kevin_Yan
Hi Kevin,
To get the best experience on Zwift, I recommend you save money on the bike and spend it on a Smart Trainer.
If you buy a cheap, second-hand real bike and pair it with a Smart Trainer (instead of buying cadence, speed or power sensors) you create your own “smart bike” which can give you the full Zwift experience.
By “full Zwift experience”, I mean that the right smart trainer takes data from Zwift and changes resistance automatically to simulate going up and down hill.
For me, that’s a fundamental part of enjoying Zwift. Any old bike can work; it just needs working gears and a way to drive the trainer via a chain or wheel.
Here’s a great resource to check out:
Hi Paul,
thanks for the reply.
I have a normal mountain bike. Does it work with those smart trainers?
Should work with wheel on trainers…get a smooth tire.
hi Mike, very detailed article. It explains well. Thanks
hi Chris, do I need to buy an HR monitor separately or just use Garmin’s one.
If a recent chest strap, it should work. If it is optical built into a watch, make sure it broadcasts. I think, but not sure, early versions did not broadcast.
Hi Kevin, “direct drive” trainers transfer power directly from your chain to your trainer so they work with any bike - mountain or road - so long as it has gears and a chain.
“Wheel-on” trainers need a hard, smooth(ish) tyre to transfer the power from your wheel to the trainer. If you can put a road wheel and tyre on your mountain bike, that should work.
I recommend you have a look at the different trainer specs and prices to see what works for you. I found a second-hand smart trainer for ÂŁ110 on Facebook marketplace and paired it with a donated old touring bike with worn out tyres and no brakes.
