I’ve done rides in NYC and London since the update, the most notable change being the shadows.
I’ve saved the logs for both, to be able to check the framerate stats with Zwiftalizer, but tomorrow’s L’Etape stage is going to be the pressure test
I did the L’etape stage this morning, and the frame rate was fine except predictably (with 4000+ riders) at the start.
There were also a few other areas where the frame rate dropped quite low - these were the biggest at the towns at about 11-12km and the start/finish, and a lesser drop at around 17km (another town?). I couldn’t see what might have been the cause, the areas looked pretty plain (no trees casting shadows on a lot of riders, for example), so perhaps some optimization could be done in the future.
Compared to last week’s stage 1:
On my rides in NYC (9th Jul) and London (10th Jul), the frame rates were 30 (P5 of 23) and 41 (P5 of 28) respectively, which I’m perfectly happy with.
Just as a comparison, my older PC (AMD A8-3850, RX560), which I only use for races, gets a much worse average frame rate (19fps and 18fps in my last two Wednesday races). So the tablet is more convenient and performs better, just the occasional Bluetooth power dropout of doom that keeps me from using it for races.
Side note: I finally figured out today Zwift chooses the High profile for this PC, probably because the GPU is fast enough, but the CPU is not. I’ll tweak the profile to see if it can be improved.
@Henk_de_Beer
We saw low frame rate problems with this specific event (July 11 @ 16:00 UTC) across all OS platforms. It’s almost certainly not an Android-specific issue.
Other instances of the L’Etape events today didn’t seem to have this impact, and we’re investigating why. We’ll keep you updated on this thread
Not impossible
It was only really bad at the start with so many riders (which I expect and understand), and then passing through a few specific areas - same place each lap.
So in my case probably just a weakness in how my tablet’s GPU deals with something specific (ex. shadows of the crowds in town areas? Not sure, will have to ride through at much slower speed to have a good look ). I’m actually quite happy with the avg frame rate, considering the number of riders - just letting Will know the result of the graphical update for the M6 tablet.
By the way, as many have already mentioned, the France world looks great!
Has anyone tried Zwifting on the HUAWEI MatePad Pro? More powerful than the M6, so I guess it will work well as long as you can get around the lack of Play Store.
I also have a problem pairing ANT+ devices on my mobile phone, I have:
Huawei Nova 3e
Android 9 (EMUI 9.1.0)
ANT+ USB stick with USB-OTG adapter
Zwift game v53343
ANT Radio Service, ANT USB Service, ANT+ Plugins Service
Location and bluetooth services enabled and granted to Zwift
Wahoo Tickr HRM (BLE/ANT+)
Wahoo Kickr SNAP (BLE/ANT+)
Garmin Cadence Sensor (ANT+)
Using the Wahoo training app I can pair up all 3 sensors no problem. I believe the Wahoo devices are connecting over Bluetooth and the Cadence sensor is ANT+ only so it definitely is pairing over ANT+. So the ANT+ connectivity is working on the phone.
When I try to pair device in the Zwift game, it doesn’t find any sensors using ANT+. e.g. if I turn off Bluetooth on the phone and only try to pair with ANT+, it doesn’t find any of them. When I enable Bluetooth, it will pair to the HRM and Kickr SNAP, but no luck with the cadence sensor.
I read in another forum entry that ANT+ on Android 9 doesn’t work. Is that true? Can someone from Zwift confirm that? I’ve looked everywhere and I couldn’t find information on any specific Android version requirement for using ANT+.
I checked my Android permission using ADB and didn’t find any permission relating to ANT or DSI. Someone mentioned maybe needing to set a permission that was not present in the UI (I couldn’t find that permission in ADB). Is there some setting/permission that the Zwift game needs to be able to detect ANT+ devices that somehow has not been granted?
On my Xiaomi Mi Pad 4, I couldn’t find the permission in the settings menus, but could enable it via ADB.
On my Huawei M6, no such luck - can’t find it in the menus, can’t enable with ADB. Almost as if Huawei blocks the permissions from being installed, not sure if that is possible.
Everything comes up good on Ant Tester except that ANT HAL Service is not found. Is that something I need to install? Didn’t find anything matching in Play store.
The fact that ANT works with the Wahoo app on your phone makes me think it is a different issue than what I’m having - if I press on the red locks in the above screenshot, I’m taken to the Radio Service permissions window, but the required permission is not shown. I tried contacting DSI (no response), and Huawei (not very useful at all).
Since the latest update specifically mentions improvements for Mali GPUs, I had a look on Friday evening.
I’m not sure what changed, but it does look nice on the M6
I ran the log through Zwiftalizer, and interestingly it is running at almost EXACTLY 25fps, so I assume there is VSYNC or something happening:
Hello Henk!
For mobile, we tuned the terrain rendering to use a better distribution for coordinate values, which resulted in less clipping between road and terrain, most notable on MALI GPUs.
On Android, when battery level < 50 %, we cap to 25fps. It gets limited further as the battery level drops. No changes were made recently.
iOS is similar but uses slightly different values. On Desktop, I think the BATTPREFS tag can be used to control that.
any chance of improving the graphics profile on newer, more powerful tablets such as the samsung s6? it’s making me crazy that apple tv (4k) looks dramatically better in a side by side comparison. this should not be the case given the superiority of the snapdragon 855 chipset
Hello Ron,
The Tab S6 does have our highest graphics settings (for mobile) enabled. Due to time and resource constraints, we haven’t pursued enabling more graphics features for mobile, beyond the high quality shadows. But we could, esp now w/ chipsets like the 855. It is a beast!
(relatively)
I haven’t personally done a side-by-side comp of ATV 4k vs Tab S6.
Now I want to.
Thank you for your suggestion. I will pass it along.
-Will
