It might happen but you should not make a purchase decision with that expectation. It’s quite possible that compatibility with riser devices may come with a second generation of the Ride frame but not for the first.
I would say very unlikely, it would be a totally different front leg design since the rizer (or the Wahoo Climbr and others) needs to sit where existing mono-fork leg is.
Someone with some metal crafting skill could create something that would link from the attachment point of the current Zwift riser foot to the axle attachment points of the rizer mechanism*. But I suspect there’s not enough perceived market from anyone to do it as a purchasable product.
*it would also require the rizer to be further forward that usual so would reduce the effective slope simulation, say only giving 4° actual when it thinks its doing 6°. It also potentially changes the force loading on both ends so you wouldn’t be able to talk to Zwift or Justo about warranties or guarantees if either breaks.
Caveworks is sending from the US. I was looking for it but sending to eu is at this moment a little tricky. It is difficult to calculate the extra import costs
Hi @rroijackers, welcome to the Forums! I’m Francisco from Zwift Support.
The Elite Justo 2 is compatible with the Zwift Ride Smart Frame, as it appears on the list of supported trainers, so it will work smoothly with the frame. I do appreciate your feedback regarding the Elite Rizer, as it isn’t compatible with the Zwift Ride.
Folks, FYI: You can review all the alternatives here:
Thanks for the answer. I know the Justo 2 is compaitble. But as the topic shows is my question about the elite rizer. Maybe my english was not so clear, it’s not my major language.
I hope that zwift will come with a solution because now wahoo, elite and garmin has gradient simulators. Maybe a replacable front feet as an expansion or something.
