Hi. Don’t know if anyone can help.
Been using zwift quite happily normal Wi-fi router but there were black spots in my house.
Signed up for by whole home Wi-fi. There is a router and then discs you put around your house.
My Apple TV is connecting to the disc because it is the nearest point. But when I go on zwift there isn’t any other riders. Apparently due to low Wi-fi signal but the signal is stronger than it ever was.
I am also planning a extension so my zwift set up will be moved further away from the router and will have to be set up on the disc/repeater.
I’ve read that Apple TV and zwift spent ‘like’ repeaters…is there anyway i can sort this?
