Zwift Ride Thru axle tightness
When I tighten the rear thru axle so that the rear end doesn’t wiggle it’s so tight that I can’t back peddle. If I try to back peddle it “drops” the chain. What am I missing ?
Thanks, Scott
sounds like might be missing the drive side spacer on the trainer.
You might be missing the drive side spin cap. That’s a common reason for the frame binding against the cog when the thru-axle is tightened.
Thanks, I’ll give it a try
