Zwift Ride and Trainer Woes
Hey,
got a Zwift Ride and am enjoying it. Nice and solid. Came with the Kickr Core 2 (I had version 1 and loved it). I also had a NIB Tacx Neo 2T to compare.
The Tacx works really well. Tracks within a watt or two with my Assioma Pro RS-2 pedals. Virtual shifting is instantaneous. I enjoy the downhill drive. The road buzz feature works but is kind of weird. However, while the power is accurate, generating power is another story. Queue the whole “Tacx Tax” thing. Per my calculations I can only produce 6ish percent less power for sustained max efforts, very likely the difference between sticking with the front pack and getting dropped up the Volcano climb this week. I think it must have something to do with the way it does inertia.
I started using the Kickr Core. The good news is that I could produce my normal power. Bad news is that that power is only reflected from my pedals! depending on the scenario (ERG seems particularly bad), it’s 4-7% low very consistently. The secret spindown may have shored that up by 1%.
additionally, the virtual shifting is much slower and almost a gradual buildup in a bad way versus the Tacx.
I have to run the Kickr on Bluetooth now (seems to have no effective on the quality of the virtual shifting) because I get random dropouts via Bluetooth.
So, for me, either trainer is a compromise. Enjoy a good training experience but potentially lose a chunk of watts in races or have slow shifting and be forced to pair power with my pedals instead of the Kickr Core 2.
I think I’m going to return the Neo and probably just have to eat the Kickr. I tentatively placed on order for an Elite Justo 2, but I understand those have had issues with virtual shifting and the Zwift Ride as well.
advisable to get a Kickr v6 instead of all of this?
Don’t have a ton to add here other than to say you’re talking about comparing two low end trainers that upon release costs 1/3rd as much as what you’re comparing it against which is well known to be accurate.
My other take is that my Pro RS2’s also seem to give me slightly high sprint numbers when compared to my Kickrbike V1. I haven’t triple recorded before even though I can between a Tacx2T and MageneP515 and my RS2’s, but.. I’m too lazy for that and only ever take the power from the kickrbike or the tacx in Zwift.
My RS2s haven’t always been higher on sprints, sometimes they’re pretty comparable, but more often than not they’ve read high on average 3-5% seeing up to 8%. Could it be heat buildup? Dunno. I don’t generally recalibrate them in the middle of a ride (guess I should try it sometime).
But long story short, I think it’s crazy you’re expecting budget trainers known to not be extremely accurate try and beat something that is has a history of being the opposite and a price tag that came with it… and what’s actually upsetting you is what you might have thought your sprint power might have been without having the data to support it…
I think you’re misplacing the issue, and a v6 might just prove that theory as well.
But remember that the V6 is still a downgrade from a 2T with just a physical flywheel, no roadfeel, lower grade / resistance, and requires power and internet connection.
Thanks for your reply.
Point of fact, I’m referring to a positive experience several years ago with the Kickr Core 1 (quite reliable and good power) and my current experience with the Kickr Core 2 and TacX Neo 2T. I have ordered an Elite Justo 2.
I am not “crazy” for expecting a product to meet manufacturer’s claims. The Kickr Core is claimed to have +/-2% accuracy (not consistency, accuracy). I have established with a ton of data that my Faveros are accurate and consistent with another good meter, my spider-based Quarq. The Faveros are claimed to be within +/-1% accuracy. Therefore, there should never be more than a 3% difference between average power across a ride of reasonable length that doesn’t involve a ton of power surges.
Not only is there consistently a more than 3% difference, that difference always has the same valence (4-7% low).
I’m not comparing sprint numbers. I don’t expect sprint numbers to be particularly consistent just based on sampling frequency. I’m talking about 1 minute to 60 minute power. I track HR, ventilatory, power, and often heat and sweat data. I generally know exactly what my typical power numbers are for a given effort level and duration.
finally, the Kickr Core has long been considered a mid range trainer while the Neo 2T, Justo, and Kickr have been considered premium.
It is expected that a trainer will report less watts than what you see measured at the pedals or cranks, because not all of the watts at the pedals arrive at the trainer. This is usually a few %. Then there is the claimed accuracy of the devices (1% for Assiomas, 2% for a Kickr Core 2). So if you ask Wahoo about this, they are going to look at modest differences and explain it as the combination of those two factors. The way I would approach it is to dual record a single activity so you can quantify the difference. I didn’t notice you saying that you had done that, so if you haven’t, take a look at this: How To Use ZwiftPower’s Dual Recording Power Analysis Tool | Zwift Insider
There are some other options out there but that would do. If you share some screenshots of the results you’d probably get some feedback about it.
Wahoo trainers also have this option you could try: https://support.wahoofitness.com/hc/en-us/articles/115000506290-ANT-power-meter-trainer-control-with-the-Wahoo-app
I have been very through in comparing dual recorded rides. Here is an example of a race that was actually one of the better performances from the Kickr Core 2. I used the Assiomas for Zwift and recorded the Core on my head unit. So, the Kickr Core 2 is the lower value.
I think if you show a 4.2% difference to Wahoo they are likely to explain it as I described above, but there’s no harm in asking. The two power sources should not agree.
I can see that people would rather frame this as something explainable whereas I know that it isn’t. Wahoo doesn’t use a power meter, they calibrate each trainer for braking forces, meaning that drivetrain loss has nothing to do with it. They also acknowledge that their trainers are corrected to match power sources further up the drivetrain (e.g., spider and pedal-based systems).
it also doesn’t account for the close agreement between the Neo 2T and my pedals.
Perhaps a more succinct way to ask my question: how do people like the Justo 2? Have any of the virtual shifting issues been addressed? How does it compare with the Zwift Ride to a Kickr v6?
I’m not trying to justify the various products you are using, just trying to offer the information that you might get from a manufacturer if you present that data to them. I hope you do that and share their response.
I have no experience with the Justo 2 so can’t attempt to answer the other part, other than to say that you can’t get virtual shifting when it’s paired via WiFi yet because the feature doesn’t exist in their firmware yet.
It should be noted that power meter accuracy is to itself, not a static global.
That is all that number means, and that is the standard.
That is not true. What you are referring to is internal consistency. Different construct.
Accuracy is established against a known torque or dynamometer. When a manufacturer says “+/-2% accuracy” they mean that their product, under appropriate operating conditions, should be within 2% of “true power.”
Without this, e-racing would be totally useless.
I don’t have a justo 2, I have a justo 1. I use virtual shifting connected by bt and it works great. I have not had any issues with the virtual shifting. My guess is it would work just as well on justo 2.
Things we also don’t know; not that I’ve looked very hard, but it’s definitely not common that manufacturers share what their in-house testing parameters are to define their accuracy.
So again, the whole concept of sprint power accuracy is not going to be 1:1 between power meters because I don’t believe any manufacturer does sprint/burst speed accuracy checks (if they do, they aren’t going to knock themselves down to saying their product is 2% accurate over 1% accurate)
Yes, obviously this stuff is compared to true watts, but my point is that everything measures power differently, everything uses different algorithms, everything has different smoothing and features etc. But if they can hold 1kw on their power meter and have it sit at 1kw.. they’ll call it accurate.
I’m sure some do burst tests, but I guarantee most manufacturers are willing to bend the truth.
Maybe I’m getting lost in what you’re after though or why sprint power was ever part of the topic in the first place… so leaving this tunnel.
From what I’m finding though the Justo is definitely more akin to the Tacx than the Kickr; similar max grades, allows rocking, can run without outlet power.
But yeah, the Justo2 is just added wifi and a casette with purchase, so just look for Justo1 reviews because it seems 2 is indeed rare.
If anything it seems like wherever / whenever there are issues tied to virtual shifting is when trainers are set to racemode / high refresh rates, but that seems to be universal-ish. Not saying everyone has issues, but that seems to be a common denominator for many.
Thanks.
I literally have never mentioned sprint power except in response. I really don’t care about it as my sprint is modest at best. Differences in sustained power bother me quite a lot, though.
