I have the same problem, my avatar steers to the left sometimes when I start riding on Zwift but also the problem starts during during a ride/race, after working perfectly for an hour, . It is pretty annoying in a race because I can’t draft anymore. I already did a re-calibration and sometimes this works and sometimes it doesn’t.
Also the battery of the left controller runs down faster.
Any idea how I can solve this?
Ask support about replacing it
Hi @Steven_De_Nys, thank you for bringing your concerns to the forums!
I’m Fernanda, from Zwift.
I just wanted to chime in on this issue you’re dealing with and let you know that I’ve found your ticket and replied to you via email with the next steps to follow! Let’s work together to find a solution!
See you via email.
Would it not might be helpful if you shared the next steps out to the community?
I have encountered the same “pulling left” issue. It’s clearly a hardware related fault in my left controller.
A temporary fix I have found is to press the lit Z button on the left controller to turn it off and then turn it back on. That generally remedies the issue for the balance of the current Zwift session.
Hi @Eric_Oshlo, thank you for bringing your concerns to the forums!
I noticed you’ve opened a ticket with our support team. Just wanted to let you know I’ve already replied to your email. If the issue continues, a replacement might be needed. Keep an eye on your inbox for all the details!
Talk to you soon via email!
