Zwift Play Controller (Left) stopped connecting
Both ZPCs charge up, but in the past 2 weeks when I press the Z button, only the R one lights up and connects. Left one will not light up, does not connect. No longer works with my setup. Is there a way to reboot? update firmware? Is this a known problem?
Reset is done by holding down the power button for 30+ seconds
Firmware updates are done on the Equipment menu in the Companion app, but if it’s powered off then a firmware update will not be possible.
I recommend contacting support if you are stuck
