My zwift play remains breaking thereforI can’t zwift anymore
Have you tried reducing brake sensitivity to 0 in settings?
Hi @_Sanneman_827_BEAT welcome to Zwift forums.
Shuji at Zwift HQ here. Have you disabled the braking button in the game settings menu? It will appear under the Hardware tab if your trainer’s Power and Resistance signals are paired, and your Play controller will also need to be paired. Only then will the Braking sensitivity option become available in the Settings menu.
If Braking is set to OFF and you’re still getting this problem, please contact our Support Team offline. It is possible there’s a hardware issue with your Play controllers. We don’t handle these matters on a public forum because they’ll need to confirm your private information.
I switched off braking and I can ride (on) again. Will check software update to see if this will solve it.
