Hi when I use zwift on my Apple TV, it seems not to work properly. I did the three sisters and didn’t change gear once. The ride felt far to easy. When I did a time trial I was at least 4kmh faster than when I do it on my Mac. My Mac works fine it’s just the Apple TV. Any advice would be welcome.
I suspect you’ve either enabled ERG mode although I’d still expect gear changes on the 3 sisters route or the trainer hasn’t paired correctly at start-up.
As the other poster said, perhaps you have gotten ERG mode enabled or haven’t correctly paired your trainer (what trainer are you using?) connected properly as Power Source and Controllable. You might also check the Trainer Difficulty slider in the Settings menu to see where it is.
