Zwift Coach: where is the personalisation?
I signed up for Zwift Plus hoping Coach would turn my goals, current ability and available training time into a meaningful plan towards a planned event in April.
Instead, this week I’ve been given three rest days, fourth in under a week, and just 3 hours 8 minutes of riding, despite making around seven hours available and wanting to build on my existing training.
I understand recovery matters, and I don’t expect every session to be hard. But a personalised coach should make it clear how the prescribed training relates to your current fitness and how it will help you progress. If there’s a reason for such a huge light week, explain it.
At the moment, the plan feels like generic, copy-and-paste, rather than something built around my circumstances. I’m left adding sessions myself to get the training volume I was looking for, which defeats the purpose of subscribing for coaching.
A useful AI coach needs to demonstrate that it understands your goals, abilities and available time, and uses that information constructively. It should build confidence that you’re following a sensible path towards your event. This experience has done the opposite, and I’ve requested cancellation of Plus.
Are others finding their plans reflect the information they’ve supplied, or seeing the same disconnect?
Mine gave me less hours than I had said I could do. My first thought was that it had looked at my previous few weeks/months.
I then changed my Experience in the plan from Amateur to Competitive and it immediately added extra hours and days to my plan.
I’m hardly qualified to advise but I think offering only 4 Experience options is limiting. I chose Amateur because ideally I would not wish to ride over 1 hour in any one session but I’m happy to do 4-5 one hour sessions a week. [ I appreciate a two hour session a week might be beneficial ]
Possibly asking you three separate questions might suit individual tastes better:
Number of hours per week.
Number of days per week.
Maximum length of any one ride each week.
Worth remembering that if, say, your last 6 weeks has you riding on avg 3 times a week for a total of 3 hours, that’s the start point that the AI will use.
It’ll then progress you with guard rails so you don’t ramp too fast. Obvs none of us knows where those guard rails are, but I suspect fiddling with the parameters (especially experience level, it seems likely) will change the position of those guard rails and thus the riding prescribed.
Cheers, I understand why recent training would be used as a starting point, and sensible limits on progression make sense.
But surely improvements in fitness, after cycling three times a week for six weeks, the answers given during setup, your goals and the hours you have available should also influence the plan? Available time doesn’t mean every hour needs filling, but I’d expect those factors to produce a meaningful, personalised progression.
In my case, I’m seeing three rest days this week with a forth from last Saturday with 34min session given on my chosen long day, and just 2.5 hours of riding this week, without a clear explanation of how that relates to my current fitness or April event goal. If it’s deliberately reducing the load or establishing a baseline, explain why and how things will progress.
The options offered to adapt the plan should also work and produce changes that reflect the information supplied. Otherwise, what’s the purpose of asking those questions and offering those options?
Everything I can see so far feels generic. I shouldn’t need to fiddle with settings and guess where hidden guard rails sit to get a plan that reflects what I’ve already told the coach.
Something definitely feels off for you. My training score is currently 44 and it’s happily giving me the 6 hours a week I asked for and a 3 hour ride on my long day.
Yeah something out of sorts for sure.
Part reason I went on to plus, was for structured progression but getting more by myself.
It May be early doors for them but issues shouldn’t be ours to fix or pay extra for.
All the best & cheerz for your input David… Ride on
