Since moving to Virtual Shifting, Zwift disconnects from Bluetooth, Wi-Fi, and drops my connection completely, even dropping my companion connection. I never had this problem with a Bluetooth connection to a Quarq/HRM and Wi-Fi to the Kickr V6 before moving to virtual shifting and everything about my setup is unchanged.
Log: TrainerDX
Any help is appreciated.
What happens when you pair everything via Bluetooth? Which firmware are you running on the trainer? Is firmware up to date on the Ride controls?
Yesterday I rode for 90 minutes using Wi-fi without a dropout. Today I had several so I ended my ride, rebooted my computer and tried again. 20 minutes in I had another drop out so I switched to Bluetooth midride and it was fine for an hour. The Kickr has the latest firmware but have no idea what firmware the ride controllers are on. I just received the V2 Ride on Thursday so it can’t be terribly outdated.
I’ll stick with Bluetooth for now. If that fails, I’ll reluctantly use the Direct Connect.
