I’ve linked my garmin footpod to my Viiii HRM, it then shows in Zwift iOS and I can connect to the Viiii bridged sensor, but when I run I don’t go anywhere!
I have unpaired my watched and footpod and have the 4iiii app closed, does anyone use this setup and have you got it to work?
I looked at your activity over the last few weeks and in each of your “log out” sessions, it’s only showing the ride sport, not running. Are you selecting the run sport at the pairing screen? Try closing your Zwift iOS app and then open a fresh session, then select Running as your sport. I don’t recommend switching back and forth between running and cycling in the same session. Force close the app before switching sports.
If that doesn’t help, please submit a support request if you haven’t already done so, and a Zwift team member will be happy to take a closer look at this matter.
