Our set-up has developed a rather annoying aspect: the chain frequently lurches forward when almost any pressure is applied, and it gets worse with increasing pressure.
This is easily seen in a slow-mo video we posted at 22, 37, 40, and 43 seconds (links are not allowed here, apparently, so here’s the ID on YouTube: yj2M-XBNg3M).
The chain is almost brand new. This frame with its previous chain was fine for over a year. This started happening, so we replaced the chain, but that did not help the situation.
The teeth on the Hub cog do not appear to be worn.
What’s causing this and how to remediate it?
-Ken
looks like something is throwing it out of alingment, is the chain line straight with the front chain ring?
Looks like the skipping links of the chain aren’t engaging on the teeth, could it be that there is either something on the spacers around the cog that grab the chain or the cog has some teeth that aren’t worn the usual way but rather somehow flattened at the tip?
But of course it could still be just a regular worn cog, did you actually take a close look at the teeth?
Great video. Chain is definitely jumping off the teeth.
Assuming that the derailleur is adjusted properly (which I can’t tell from the video but if you post a photo from directly behind the derailleur that shows the path the chain takes from the cog to the top pulley, that might reveal it) I would send this video to Zwift support because they may send out a replacement cog for you.
If adjustment is the problem, review this:
Thanks, Paul. I thought Support would see it here, where do I contact them? I looked through their Support section but didn’t find a way to do that. Here are photos of directly behind to show alignment, see anything amiss?
Just email the pics and the video link to support@zwift.com
Chain alignment looks close enough to me
Hard to tell, but did you route your chain incorrectly around the pully here?
Good call. That looks like it went under the guide instead of over it.
Hi Mike,
While you did correctly spot a misthreaded chain (thanks!), correcting that did not resolve the lurching of the chain.
We have now tried another bike and it had no issues, so it’s not the Cog unit that’s the problem.
Support had us try different Cog settings. It’s always been in position #2, so we tried #1 and #3 to worse effect. We also took off the bike and reseated it, checked alignments, and examined the derailleur’s little cogs, which appear to be fine.
What we’re currently wondering is whether that chain is the issue - could it be too long? poor quality?
-Ken
You should take the bike to your local bike shop and have them service it, explain the issue you are having, even take the trainer with you if needed. The bike mechanic will be able to figure it out.
Which chain did you buy?
Any chance there is a stiff link in it? That’s usually visible if you pedal the bike backwards and watch how it passes through the derailleur pulleys.
We went to REI to get the new chain, but they didn’t have one in stock, so got one from Wal-Mart iirc. And yes, it might have a stiff link, or even two, but when pedaling with a fair amount of pressure it will lurch in multiple spots. Maybe the chain is of such poor quality that it actually has many bad links.
Might be worth trying a better chain. Exactly what to buy depends on the drivetrain details. If you share that I could suggest something.
It’s a very dry looking chain. Looking through the front derailleur cage the spacing between chainrings looks huge. Is that a triple (3x) chain set on there? If you try a different chainring and realign the Cog, does it still have problems?
Wow, you’re eagle-eyed
Yes, it’s dry because we wiped it well during all the recent handling. Normally it’s well lubed. And yes, it’s a triple chain ring on the front: it’s a Specialized Allez and it came that way. We don’t have chainrings lying around, so no way to swap in another.
Until recently this setup worked fine, triple ring and all. The other bike we tried also has a triple chainring and it’s fine. We’re going to get a decent new chain on Monday and see whether that takes care of the issue.
If you still have the old chain lying around, make sure the new one is the same size and length.
I just meant to move it from the inner ring to the middle or outer ring.
If you stop your video at 21, 35, 39 and 45 seconds you will see that the chain coming around the cog is not meshing with cog teeth cleanly.
As others have said probably due to tight links. The attached video might help you easily identify if it is tight links and if so how to easily fix.
If you don’t have tight links it might be that the new chain is not a suitable size however your original chain started causing the same issue. Did your new chain work for a while or cause this problem from day one?
If you are buying a new chain I believe a standard 3/32” narrow chain for 8-12 speed is recommended.
The cog2 looks quite well used - has it done many miles? If you do buy a new chain it might be best to take the Cog2 with you and ask them to look at it. Often best to replace both chain and Cog at the same time. A good bike shop should be able to easily do that for you.
Hi everyone -
A new chain from the local bike store resolved this with no other changes to the bike, hub, or cog. Lesson learned: don’t ride with a cheap chain.
Thanks, all, for taking the time to reply and making your various suggestions!
Ride on,
-Ken
