Zwift Freezing on MacOS 27 Golden Gate
Having an issue with Zwift hard freezing which has now happened twice since upgrading to golden gate on M2 Mac Studio.
After upgrade the first launch of Zwift worked but I noticed it went through all the startup screens slow, I assumed maybe it was just overall system indexing etc. However when launching into a route it started to load (could see a bit of the world) and then just frozen. After about 5 mins it might proceed another few frames but then hard freeze again. App shows as not responsive.
I deleted Zwift, restarted computer, reinstalled Zwift and it worked ok for a couple of days until today while I was riding it froze. Same thing every 5 mins or so I might move another few frames along the route but then immediately frozen again. Force quit and restarted computer/zwift a few times and every time the same where the startup screens are a bit slow to load through and freezes when launching into the world.
Deleted zwift and reinstalled again and again working and I can load into the world fine and it’s not frozen.
Never had any problems with Zwift before and am a heavy user so a lot of data points, so definitely feels like some issue with Zwift and/or Golden Gate.
Likely it’s a different bug but I did notice that at around the same time as this most recently freeze I lost audio on external monitor and videos would not play correct in web browsers. Some threads on other forums where folks have seen similar issues with video playback on external monitors and losing the ability to output any audio. I don’t think the timing was exactly when Zwift froze, I believe the most recent Zwift freeze happened 5-10mins after that when I was changing sound output in preferences trying to debug. First Zwift frozen occurrence none of this happened was just on fresh boot after OS upgrade.
edit 1: I should add that for this second freeze event I did have a flashback to a zwift issue where iCloud document folder syncing was causing an issue and I think you lose the ‘keep downloaded’ setting on the Zwift folder when you delete and reinstall. I changed to keep downloaded and ensured sync’d correctly and testing and the same freezing issue.
Happened again this evening except this time the entire computer froze and screens eventually went black. Hard reboot and after startup launched zwift and it’s back to the slow load/frozen state. Are there any files or some logs with it in this state that would be helpful to troubleshoot? Seems it must be zwift specific files since flushing them and reinstalling fixes.
I wonder if it’s related to rebuilding the indexes for Spotlight (etc) after the OS upgrade. I mean it should handle that gracefully when you are using the machine but that’s the only thing I can think of. You could temporarily disable indexing on the system volume and test again.
Quite a few people have been running Zwift on macOS 27 already and you’re the first to report this issue in public AFAIK.
macOS 27 currently has a known bug with CoreAudio when routing audio directly over DisplayPort or HDMI to an external monitor.
Because Zwift’s graphics and simulation loop rely on the system audio clock for frame timing, a stalled audio driver causes the entire game loop to deadlock. This manifests as severe freezes, missed server packets, and network timeouts (even though your internet connection is fine).
You don’t need to reinstall Zwift or wipe your network settings. Just change the audio sample rate:
Press Cmd + Space to open Spotlight, type Audio MIDI Setup, and launch it.
In the left sidebar, select your External Monitor (HDMI / DisplayPort Audio).
On the right, change the Format (sample rate) from 48,000 Hz to 44,100 Hz (or any other available rate).
(Changing this forces CoreAudio to re-initialize the driver cleanly).
Alternatively, switching your audio output to Mac Speakers, Headphones, or an external DAC immediately resolves the freezing.
I had the severe freezing on my MacMini M2 yesterday.
I did a reinstall of Zwift which didn’t help.
Several restarts also didn’t help.
I then noticed I wasn’t getting sound over HDMI, so I was troubleshooting that for some time. It wasn’t just Zwift not doing audio - it was anything. Audio would play over the Mac speakers, but not HDMI.
I sorted that out by plugging the speakers into the Mac headphone jack, and then Zwift worked fine, so I guess the switching of audio output was the key to getting Zwift to work without freezing.
I should have updated the thread but yes I had kind of figured this was the issue as at the time I noticed I was having issues with youtube sound and even youtube playing at times. I had ran into these reddit threads that detailed the issue and the MIDI sampling rate fix.
For what it’s worth I still have issues though. When I quit zwift if I re-launch Zwift it will go into the freezing mode, and won’t resolve until I reboot the computer. I haven’t tried to debug more due to time and just leave zwift running. I do have two external monitors. My original youtube issues were on my main while I run zwift on the second and mostly I’ve just needed to change the sampling on the main. But now I’m wondering if the sampling on the second also needs to be changed and likely the issue, I will give it a try later.
I am using Golden Gate on M4 Pro Mac Mini with 55" 4K TV screen running over HDMI cable, I am not having any freezing. I do have audio muted however.
I think the issue is when you have 2 monitors
That I can try, I have a 5K screen I can connect to the M4 Pro Mini via thunderbolt cable. Doesn’t work with my M2 Macbook Air, it only supports one external screen (sigh).
Just wanted to update that I changed the sampling on the 2nd external and that solved my inability to relaunch zwift without need to reboot computer. I figured this would be the case, just never changed the sampling there as didn’t have the youtube video/audio issues there and changing just on primary external solved those issues. Hoping apple fixes this soon.
