The app is crashing within 10 minutes after starting riding. I tried to reduce the resolution thinking that would be a GPU issue but that did not fix the problem and that was not happening before.
not only crashing, my entire computer freezes and restart.
I literally cannot use Zwift anymore:
Zwift Log:
Date/Time: 2022-07-25 17:58:55.438 +0200
End time: 2022-07-25 17:59:14.887 +0200
OS Version: macOS 12.4 (Build 21F79)
Architecture: x86_64h
Report Version: 35.1
Incident Identifier: 82586926-1D51-42FC-804C-4894A9F63724
Data Source: Microstackshots
Shared Cache: 398ACFB4-57F6-31E0-BC82-E9959E5C92CE slid base address 0x7ff81e9f1000, slide 0x1e9f1000
Command: ZwiftApp
Path: /Users/USER/Library/Application Support/Zwift/ZwiftApp
Codesigning ID: ZwiftApp-5555494465a8b976a0af398299903e38fa8f3310
PID: 53035
Event: wakeups
Action taken: none
Wakeups: 45001 wakeups over the last 19 seconds (2314 wakeups per second average), exceeding limit of 150 wakeups per second over 300 seconds
Wakeups limit: 45000
Limit duration: 300s
Wakeups caused: 45001
Wakeups duration: 19s
Duration: 19.45s
Duration Sampled: 13.16s
Steps: 9
Hardware model: MacBookPro16,2
Active cpus: 8
HW page size: 4096
VM page size: 4096
Boot args: chunklist-security-epoch=0 -chunklist-no-rev2-dev
Fan speed: 2526 rpm
Advisory levels: Battery -> 2, User -> 2, ThermalPressure -> 1, Combined -> 2
Free disk space: 804.72 GB/931.55 GB, low space threshold 3072 MB
Heaviest stack for the target process:
8 start + 462 (dyld + 21790) [0x111a1d51e]
8 main + 790 (ZwiftApp + 19751814) [0x10f839386]
8 CODEmain(int, char const**) + 11 (ZwiftApp + 19538251) [0x10f80514b]
6 ZwiftInitialize(int, char const**) + 18764 (ZwiftApp + 19529868) [0x10f80308c]
3 AccessoryManager::InitAllAccessories() + 13 (ZwiftApp + 14651837) [0x10f35c1bd]
3 AccessoryManager::LoadWads() + 772 (ZwiftApp + 14650692) [0x10f35bd44]
3 WADManager::LoadWADFile(char const*) + 120 (ZwiftApp + 504968) [0x10e5de488]
2 WAD_Load(char const*, WAD_HEADER**) + 786 (ZwiftApp + 781666) [0x10e621d62]
2 TJZIP_Decompress(unsigned char*, unsigned char*, unsigned int, unsigned int*, unsigned char*, unsigned char* (*)(unsigned char*)) + 128 (ZwiftApp + 230007) [0x10e59b277]
1 TJZIP_ParseDictionaryCode(unsigned char**, unsigned char**, unsigned int*) + 609 (ZwiftApp + 229190) [0x10e59af46]
Powerstats for: ZwiftApp [53035] [unique pid 152441]
UUID: 65A8B976-A0AF-3982-9990-3E38FA8F3310
Footprint: 346.50 MB -> 993.96 MB (+647.47 MB) (max 1194.44 MB )
Pageins: 1 pages
Start time: 2022-07-25 17:58:59.481 +0200
End time: 2022-07-25 17:59:12.642 +0200
Num samples: 9 (100%)
Primary state: 6 samples Non-Frontmost App, Non-Suppressed, User mode, Effective Thread QoS User Interactive, Requested Thread QoS User Interactive, Override Thread QoS Unspecified
User Activity: 0 samples Idle, 9 samples Active
Power Source: 9 samples on Battery, 0 samples on AC
1 <Frontmost App>
1 TJZIP_ParseDictionaryCode(unsigned char**, unsigned char**, unsigned int*) + 13 (ZwiftApp + 228594) [0x10e59acf2]
1 WAD_Load(char const*, WAD_HEADER**) + 294 (ZwiftApp + 781174) [0x10e621b76]
1 fread + 48 (libsystem_c.dylib + 103728) [0x7ff81ebf5530]
1 __fread + 367 (libsystem_c.dylib + 61837) [0x7ff81ebeb18d]
1 __srefill1 + 24 (libsystem_c.dylib + 61304) [0x7ff81ebeaf78]
1 __read_nocancel + 10 (libsystem_kernel.dylib + 12826) [0x7ff81ecd721a]
1 <Frontmost App, Kernel mode>
2 AccessoryManager::InitAllAccessories() + 143 (ZwiftApp + 14651967) [0x10f35c23f]
2 AccessoryManager::InitAccessories() + 556 (ZwiftApp + 14636044) [0x10f35840c]
1 AccessoryManager::AddAccessory(Accessory*, char const*, char const*, char const*) + 3331 (ZwiftApp + 14628915) [0x10f356833]
1 Accessory::GetThumbnailTextureHandle() const + 134 (ZwiftApp + 14609302) [0x10f351b96]
1 GFX_CreateTextureFromTGAFile(char const*, int, bool, bool) + 1390 (ZwiftApp + 627150) [0x10e5fc1ce]
1 GFX_Internal_LoadTextureFromTGAFile(char const*, int, bool) + 1583 (ZwiftApp + 628927) [0x10e5fc8bf]
1 GFX_CreateTextureFromZTX(void*, int, int) + 102 (ZwiftApp + 631734) [0x10e5fd3b6]
1 ZLIB_Decompress(unsigned char*, int, unsigned char*) + 225 (ZwiftApp + 602657) [0x10e5f6221]
1 inflate + 7299 (ZwiftApp + 8636275) [0x10ed9f773]
1 inflate_fast + 427 (ZwiftApp + 8625211) [0x10ed9cc3b]
1 AccessoryManager::AddAccessory(Accessory*, char const*, char const*, char const*) + 3323 (ZwiftApp + 14628907) [0x10f35682b]
1 Accessory::GetTextureHandle() const + 223 (ZwiftApp + 14608687) [0x10f35192f]
1 inflate_fast + 2250 (ZwiftApp + 8627034) [0x10ed9d35a]
1 AccessoryManager::InitAllAccessories() + 148 (ZwiftApp + 14651972) [0x10f35c244]
1 AccessoryManager::InitBikeComponents() + 3427 (ZwiftApp + 14644723) [0x10f35a5f3]
1 AccessoryManager::AddAccessory(Accessory*, char const*, char const*, char const*) + 3307 (ZwiftApp + 14628891) [0x10f35681b]
1 Accessory::GetMeshHandle() const + 685 (ZwiftApp + 14603181) [0x10f3503ad]
1 LOADER_LoadGdeFile(char const*, bool, bool) + 299 (ZwiftApp + 593387) [0x10e5f3deb]
1 LOADER_LoadGdeFile_LEAN(GDE_Header_360*, char const*, unsigned int, unsigned int, int, bool) + 752 (ZwiftApp + 594208) [0x10e5f4120]
1 inflate_fast + 1179 (ZwiftApp + 8625963) [0x10ed9cf2b]
2 ZwiftInitialize(int, char const**) + 18795 (ZwiftApp + 19529899) [0x10f8030ab]
2 BikeManager::Initialize() + 31 (ZwiftApp + 12663087) [0x10f17692f]
1 BikeEntity::LoadMeshes() + 886 (ZwiftApp + 12597766) [0x10f166a06]
1 WADManager::LoadWADFile(char const*) + 120 (ZwiftApp + 504968) [0x10e5de488]
1 WAD_Load(char const*, WAD_HEADER**) + 786 (ZwiftApp + 781666) [0x10e621d62]
1 TJZIP_Decompress(unsigned char*, unsigned char*, unsigned int, unsigned int*, unsigned char*, unsigned char* (*)(unsigned char*)) + 128 (ZwiftApp + 230007) [0x10e59b277]
1 TJZIP_ParseDictionaryCode(unsigned char**, unsigned char**, unsigned int*) + 604 (ZwiftApp + 229185) [0x10e59af41]
1 BikeEntity::LoadMeshes() + 841 (ZwiftApp + 12597721) [0x10f1669d9]
1 TJZIP_ParseDictionaryCode(unsigned char**, unsigned char**, unsigned int*) + 593 (ZwiftApp + 229174) [0x10e59af36]
1 thread_start + 15 (libsystem_pthread.dylib + 8043) [0x7ff81ed0df6b]
1 _pthread_start + 125 (libsystem_pthread.dylib + 25825) [0x7ff81ed124e1]
1 JM_Worker_Thread(void*) + 62 (ZwiftApp + 646062) [0x10e600bae]
1 OS_Sleep(unsigned int) + 89 (ZwiftApp + 227771) [0x10e59a9bb]
1 nanosleep + 91 (libsystem_c.dylib + 67578) [0x7ff81ebec7fa]
1 clock_get_time + 85 (libsystem_kernel.dylib + 23563) [0x7ff81ecd9c0b]
1 mach_msg_trap + 10 (libsystem_kernel.dylib + 6522) [0x7ff81ecd597a]
1 <Kernel mode, Effective Thread QoS Default, Requested Thread QoS Default>
Binary Images:
0x10e563000 - 0x10ffe6fff ZwiftApp (0) <65A8B976-A0AF-3982-9990-3E38FA8F3310> /Users/USER/Library/Application Support/Zwift/ZwiftApp
0x111a18000 - 0x111a9bfff dyld (957) <B70CE1EC-B902-3852-8268-05DE00BFA8D5> /usr/lib/dyld
0x7ff81ebdc000 - 0x7ff81ec64fff libsystem_c.dylib (1507.100.9) <D9BA0660-744D-3F84-9F80-AFB51D450512> /usr/lib/system/libsystem_c.dylib
0x7ff81ecd4000 - 0x7ff81ed0bfff libsystem_kernel.dylib (8020.121.3) <61711D11-E776-3BC3-B9A2-6F9F37CB8499> /usr/lib/system/libsystem_kernel.dylib
0x7ff81ed0c000 - 0x7ff81ed17fff libsystem_pthread.dylib (486.100.11) <BC574849-1AAE-31E7-B350-916DDA999D97> /usr/lib/system/libsystem_pthread.dylib
Crash report:
Translated Report (Full Report Below)
Process: WindowServer [-1]
Path: ???
Identifier: WindowServer
Version: ???
Code Type: 00000000 (Native)
Parent Process: ??? [Unknown]
User ID:
Date/Time: 2022-07-25 18:28:45.4008 +0200
OS Version: macOS 12.4 (21F79)
Report Version: 12
Anonymous UUID: 3D6AC96B-ECF8-676E-14C1-22CA3629FAC9
System Integrity Protection:
Notes:
resampled 356 of 2161 threads with truncated backtraces from 0 pids:
resampled 0 of 113 images missing from 269 pids: 105,106,107,111,124,139,143,148,154,155,159,162,164,168,170,172,176,179,181,195,233,242,243,249,251,252,254,256,260,261,263,266,268,317,318,319,320,322,323,326,332,333,334,345,347,350,354,367,368,369,371,381,384,388,394,396,399,402,407,411,412,418,421,429,434,435,460,518,525,533,541,549,552,553,556,561,575,583,600,601,602,608,616,617,618,621,624,625,630,632,638,640,641,651,653,654,667,668,669,670,672,675,677,682,683,686,687,688,690,692,696,697,698,704,705,707,719,736,788,800,802,809,818,822,838,846,858,860,872,881,882,887,902,930,944,950,960,961,964,969,970,1574,1972,2042,2046,2079,2099,2181,2201,2204,2284,2784,2793,2814,2834,2855,2862,2866,2868,2882,2883,3026,3031,3034,3036,3037,3038,4703,4705,4706,4708,4709,4715,4720,4727,4740,4755,6612,8745,8746,8747,8764,8860,11066,13119,13120,13121,15536,15950,16142,19756,20550,21083,24814,24891,24922,24955,27140,27206,27227,30625,30646,31050,32534,32543,33861,33862,33978,34054,37625,37626,37627,37699,38426,38427,45314,46083,46383,48477,48872,49389,49517,50407,50469,50497,50498,50513,50686,50691,50694,50768,50842,50876,50877,50880,50881,50897,53047,53146,53333,53341,53349,53361,53367,53368,53419,53666,55596,55901,55912,56139,56140,56397,57045,57172,57405,57415,60201,67900,72382,76464,81614,82243,85288,89434,89436,92400,92401,92405
1 unindexed user-stack frames from 1 pids: 67141
This is a watchdog-triggered termination event, and not expected to be well-represented in the legacy crash format
Crashed Thread: Unknown
Exception Type:
Termination Reason: Namespace WATCHDOG, Code 1 monitoring timed out for service
(1 monitored services unresponsive): checkin with service: WindowServer returned not alive with context:
is_alive_func returned unhealthy : Display 69734208 not ready: DisplayID: 0x4280f40
Surface Use Counts: 1(3) 3(1) 6(1)
FB RegID: 4294968424, On Glass SurfaceIDs: 6 3 1, Transactions: [ Active: SurfaceID: 6 ] [ Waiting: SurfaceID: 3 ] [ Waiting: Surface
40 seconds since last successful checkin, 218 total successsful checkins si
Error Formulating Crash Report:
Backtrace not available
No thread state (register information) available
Binary Images:
Binary images description not available
