I had that problem.
After two forced closes and waiting 5 minutes it eventually came back up.
I haven’t had the issue since then so I didn’t report it.
I had that problem.
I totally agree. I’m pleased that I was able to explain my point (however small) and someone else has the same “issue.” ![]()
[moderator redacted personal info]
@Paul_Southworth can you hide this guys personal info please ![]()
@Al_Sherman be careful what you post on the public forums on the internet my dude.
I also would like the ‘you gave X ride-ons’ message back.
Since the new update (which i really like) i don’t see any runners I follow showing as active when they are doing a run.
I would just prefer the choice to see a single colour (sky blue) rather than the changes between night and day.
Since yesterday my CA was frozen, and didn’t respond at all, now it’s working again, deleted it twice and reinstalled it, but didn’t make any difference.
And now with zwift plus videos, have to stop every few minutes to let the video catch up, otherwise all I see is a black screen with an orange band I’m cycling on , have used different devices to log into Zwift video, but this didn’t help either, very frustrating
That’s a buffering issue. Your download bandwidth to your Zwift game device is too slow and it’s exhausting its buffer of constantly downloaded video.
Might be an issue with slow wifi to where you’re positioned, rather than necessarily slow overall download to your router.
Run some download tests on your game device in the place where you’re running Zwift.
Thanks Steve. Paul pointed it out as well. Have run a speed test. Paul confirmed it’s way too slow.
Appreciate your reply and help along the way.
It’s a great community we are having here. So fantastic that everyone chips in.
Thanks mate!
I believe that is a summary only. Either select Plan or tap on the summary and it will take you to Plan where you will see the old format and full detail.
Update October 31
iPhone users please note a patch is being released to the Apple App store
Yes not many people have said anything about it, but I can tell you that Zwift developers are aware of it.
The “ride on everyone you’re following” button doesn’t work right when riding. If I switch from map over to the Home Screen and hit the thumb, it does the little animation and then disappears, and then comes back because it failed to ride on everyone. This behavior happens 100% of the time.
Can someone please bring the routes list up to date? It’s still impossible to see which event only routes have badges and which of those I have already done.
Android users - Companion v 3.91.2 has begun phased rollout.
iOS users - phased rollout is complete. Please update in the Apple App Store at your earliest convenience.
Running the latest version of Companion on iOS. The durations for some routes that are a whole number of hours plus zero minutes are appearing as “2 m” instead of “2 hr” – perhaps the coding is set to give a number of minutes that is zero and it’s dropping the correct unit for the number of hours. I’m seeing this for any route that estimates it’ll take me some whole number of hours on the nose. It shows the correct duration when there are some number of minutes to add to the total. I can send a screenshot if necessary but I suspect this will be an easy thing to spot, despite every rider’s duration estimate being different for each route.
Yes this has been reported already as of 3.91 ![]()
3.91.2 hasn’t fixed the issue with rides pulled in from Garmin not showing distance in the Review area on the HOME screen. If I go into Activities, Just Me, the distance shows correctly.
Also if the ride is set to VIRTUAL CYCLING in Garmin Connect, could Zwift also see that as an virtual ride so the little sun on the GIF animations doesn’t appear unless that same day I did a real outdoor ride? I ride on other indoor platforms that feed into my GC so they are pulled into Zwift in the companion app.
Cheers
