Zwift Companion v 3.89 [September 2026]
Hello Zwifters,
Phased release of Zwift Companion v 3.89 has begun to iOS and Android devices.
  • Zwifters who like to plan out their week now have the ability to schedule a rest day, or activities outdoors in Companion. See this previous thread for more details.
  • Stability improvements.
UPDATE September 18
Phased rollout to iOS and Android is complete.
UPDATE September 29
v 3.98.2 for iOS only
  • Made improvements to Zwift Play controller support in Zwift Companion.
  • Fixed an issue where the Next Up card could appear blank after returning from a ride.
UPDATE October 6
Known Issue with Companion v 3.89.2 (iOS only)
*The WiFi setup tab no longer appears for Wahoo trainers that support pairing over WiFi. Workaround: use the Wahoo app to set up WiFi. We will correct this issue as soon as possible.
Do you have questions or issues to report? Let us know below.
Hi ios27. Updated phone with ios27 & latest campanion app. Doesn’t to open when I start a activity. Currently doing the space invader party crasher event. Thanks brett
@brett_andrews1
The update to OS 27 may have reset Companion’s app permissions so it can’t “see” that you have the game app running on your network. Easiest thing is to uninstall Companion, reinstall, and when you’re prompted to grant permission for Local Network Device and Bluetooth, say yes.
Let us know if that clears it up?
Hi shuji
Thanks removing & reinstalling fixed it. App asked for permissions. The map now pops up when I start an event. Didn’t think of that just assumed it should work. Will have to climb alp Du zwift as punishment.
Many thanks Brett
Is it a know bug that companion app will not open when not on my wifi?
It shows a blue screen says “Internet connection required” but the phone is on 5G?
No, it works just fine using 5G here.
Go to iOS Settings → Apps → Companion and check if Cellular Data is turned on
That is the reason - I likely turned it off to force it on the wifi when zwifting - thank you :+1:
I’m having the same issue since iOS/ OS update. iOS27/ macOs27. Reinstalling the app didn’t work, including a second reinstall with device restart in between - companion doesn’t appear in the list of apps which have requested permission to access the local network. In “app privacy report” it appears to and updates network activity. Zwift has local network and Bluetooth access on the Mac and continues to work perfectly. Any suggestions?
The Mac is Ethernet connected and is set up as the wifi my iPhone is connected to. Disconnecting Ethernet and connecting both devices via a separate wifi doesn’t help.
Toggling companions wifi mobile data access off doesn’t affect it so presumably it get at least some data via the phone’s wifi connection.
Did you already re-install both Zwift and Companion? The problem can be on either side of that connection if it’s a permission issue.
I also noticed that Local Network permission toggle does not show up for Companion on my iPhone (iOS 26) but it works anyway.
:folded_hands:
Had previously only reinstalled the companion app
Reinstalling the zwift app in the Mac worked - all the expected permissions prompts appeared (allow folder/ BT/ silicon/ network access).
Problem fixed and coincidentally a longstanding BT issue resolved also.
Thank you for the advice.
I saw this anomaly with this event today - it only has a C pace listed, and there was some offset D criteria in the preview beneath it:
Will this also remedy my recent experience with the activity feed where I’ve had duplicate activities and activities that are not in time order? Thanks!
MacOS running Zwift and Android Companion app. Zwift updated on MacOS and now I can’t use the Companion App in-game. I tried deleting and reinstalling the Android app, reinstalling the Zwift app for MacOS, rebooting the Mac and Android phone, made sure permissions show Zwift with local network access.
Everything looks right, still doesn’t work. I spent like 2 hours on this today.
Adjust FTP setting through Companion is a new one :eyes:
Never noticed that in any release notes
iOS users - please update Zwift Companion to version 3.89.2 at your earliest convenience.
We’re aware of an issue that affects the initial setup of WiFi connectivity for Wahoo trainers. Please use Wahoo’s app to provision WiFi as a workaround.
[conn-3266]
Notice with the companion app this morning after installing the new Zwift update on AppleTV, there is no longer options to do lap timers?
