Anyone else having their companion app not load and then crash? It’s working on my (very old) iPad but not my much newer iPhone 16 pro. Nothing I’ve tried so far has helped and can’t get a solution from Zwift
have you updated to the most recent release from this week? Companion also has an update. Check your app store to force it to update.
Yes, I have the latest versions of both apps and hope a new patch comes out soon
There arent wide spread reports of crashes so Im assuming there wont be a patch, it seems to be working fine for everyone else.
Hi @Benjie_Hutchison_GXY,
I also flagged your support request internally with our ZC team who are investigating this issue. I know you’ve already tried all of the troubleshooting steps we’ve suggested. One additional troubleshooting step and data point, since I noticed your mobile connection was on the weaker side in the screenshots you provided, is to try is disabling these settings on your iPhone to completely rule out the mobile connection:
- Settings > Cellular > Disable Cellular Data
- Settings > Wi-Fi > Disable Connectivity Assist
That said, we are not waiting for this information from you, and we’ll follow up on your request and also post here as soon as an update from the investigation is available.
Thanks Alan, I’ve tried that too so will wait to see what the specialist team says ![]()
Thank you @Benjie_Hutchison_GXY. A few minutes ago we just pushed a back end update addressing a Feature Flag issue that should be improving cases like this. Could you please try logging out of your ZC, then force closing the app, and then re-launching and logging back in to see if it has been resolved?
Hello, unfortunately the problem remains. The initial Tour works normally and responds to touch, but as soon as I finish the Tour and reach Home, the Home screen appears but none of the buttons or other controls respond.
I’ve done quite a bit of troubleshooting already:
- iPhone is running iOS 27.2
- Zwift Companion is version 3.91.0
- Force-closed and restarted the app
- Restarted the iPhone
- Completely deleted and reinstalled Zwift Companion
- Tested over my home Wi-Fi
- Tested with Wi-Fi completely disabled and mobile data only, with the same result
- Installed Companion on a second phone and signed into the same Zwift account. The Tour works, but the Home screen then freezes in exactly the same way
- Tested the same Zwift account in Companion on my iPad, where Companion works normally
- The main Zwift app itself is also working normally on my iPad
This therefore seems unlikely to be an issue with my home network, as the problem reproduces on two phones and when using mobile data, while Companion works correctly on my iPad.
The issue also appears specifically when the Companion Home screen loads. Given that version 3.91.0 introduced the redesigned Home screen, could you please check whether this is a known issue with 3.91.0 on iPhone/iOS 27.2, or whether there is anything associated with my account that could cause the Home screen to become unresponsive?
Definitely not a general problem with iPhones on 27.2 but I’m not sure about the cause. I am using it on an iPhone 15 standard model. If Companion on all iPhones on current iOS were broken there would be a revolution.
Hi everyone,
I’m experiencing an issue with the Zwift Companion app on my iPhone 17 Pro.
The app freezes immediately after launching, making it completely unusable. I cannot navigate through the app or access the settings to log out.
Device and software:
- iPhone 17 Pro
- iOS 26.7.2
- Zwift Companion version 3.91.0 (2995)
Troubleshooting steps I’ve already tried:
- Force-closed and restarted the app.
- Restarted my iPhone.
- Uninstalled and reinstalled Zwift Companion.
- Offloaded the app and reinstalled it.
- Tested the app using Wi-Fi only.
- Tested with Airplane Mode enabled and Wi-Fi manually re-enabled.
- Confirmed that the issue persists after all these steps.
Unfortunately, nothing has worked. The app still freezes immediately upon opening.
I also cannot log out because the app freezes before I can access any menus.
Has anyone else experienced this issue recently, particularly on iOS 26? Is this a known issue that Zwift is currently investigating?
Any help would be greatly appreciated!
I don’t think your problem has been reported before on the forum.
There is one other recent failure report but it does not really match your symptoms. I recommend contacting support.
I’m having this too! Glad it’s not just me
I thought one of you was experiencing crashes and the other only freezing. If that’s true then I’m unsure if these are the same problem, but that’s for Zwift to sort out. Either way they have some work to do.
I’ve submitted a support ticket to Zwift now. I’ve sent an email to their support team. ![]()
My ZCA has frozen today too, but that was after like 2h of riding.
Sorry for the troubles. In just a little bit can you try 3.91.2 when it hits your App Store? We just pushed that version about 20min ago and it may fix your issue. I’d expect it’ll start showing up in the next hour or so. You’ll have to manually go to the app in the App Store to see the Update button.
Just installed the version and will try it tomorrow.
That fixed my issue. Thank you so much! ![]()
@Benjie_Hutchison_GXY today we started rolling out a 3.91.2 update for Zwift Companion, which should have fixes for freezing UI and crash issues. When you have a chance, could you please refresh the Apple App Store to look for the update on your iPhone? Once you have it installed please let us know if it improves the stability of your ZC app.
Thank you, I’ve done the update and it’s working again! ![]()
