Hi, is there a way to disable or remap the Zwift Click Y button during workouts? During my TrainerRoad workouts in Zwift, I keep accidentally hitting the Y button and skipping the workout phase, and I can’t find any way to rewind/undo. (as a feature, I have never needed to skip a phase manually)
It would be great if there was a way to stop this happening. Thanks!
(Edit: using Zwift on Mac laptop with Wahoo Kickr, FYI)
Thanks for the answer. I could unpair the controls for the workout in ERG mode, yes, but then how will I give out my overly generous Ride On Bombs to everyone that passes me ?
Don’t you need to hold the Y button for a few seconds to skip the block? I know it’s not a perfect solution, and perhaps you’re busy watching something while doing your workouts, but if you let go of the button while the ‘skip workout’ circle is filling on the screen (or maybe it’s just that you don’t see the ‘Ride On’ circle filling up) then you won’t skip the block.
Yes, that’s right, but you also need to hold the Z button for the Ride On bomb, and in my dilapidated, exhausted state, with fogged up glasses, it does happen that I accidentally hold the Y button instead and don’t have the wherewithal to realise until too late.
Which reminds me, you know what they should do? A tiny little nubbin on the Z and A buttons so that you can feel which buttons you are on by touch, like the F and J keys on a keyboard or the 5 on a number pad.
I wonder if you.could put a little tiny drop of epoxy or something similar that will dry hard on the buttons to replicate this… just be very careful and maybe test it on a piece of scrap cardboard or wood first.
Just did a training ride and can confirm the PSKN ™ solution works like a charm; copious distribution of Ride Ons and not a single accidental Skip Interval.
Zwift, you should definitely add some texture to differentiate the buttons on both click controller in your next version. Just make some little holes in your plastic injection molds - done.
