Zwift Beta will not connect Galazy S10 with Tacx S
I have downloaded and installed Zwift Beta for Android to my Samsung S10. I am trying to connect Bluetooth through the app to connect with my Tacx Flux S without success. I tested an S7 on the Zwift Beta app with the same failing results.
Is there a trick to pairing Bluetooth or does this configuration simply not work?
Thanks!
Make sure that the trainer is not connected to anything including your phone before opening Zwift.
Thank you Paul. I will go try that now and report back on my finding.
Update:
Unpairing all devices resolved my issue. I had to try several times but the connection has been made and it reconnected after I went for a second ride.
Thanks!
