Zwift app on PC - doesn't show the speed panel
Hub one / Zwift app on PC - doesn’t show the speed panel and doesn’t switch speeds. Before was shifting in app normally function, and today I cant see this panel and cant shift. I using app for PC with Garmin ANT+ dongle and BT. I use Play controllers for shift. I have this problem one month before, but was somehow repaired automatically.
I try different connection for Hub etc from ANT to BT and oposit. I tried turn off/on all hardware and Zwift reinstall also.
I try run Zwift on mobile and shifting with shifting bar was ok.
Thanks for hints and help. Many thanks.
To use virtual shifting with the Hub One you must pair the trainer via Bluetooth
