Zwift (1.77.0 136131) on macos (14.6.1) not seeing Kickr Core
Previous to latest (1.77.0 136131) patch to Zwift everything was fine with macos (14.6.1) and the Kickr Core.
Upon updating to latest (1.77.0 136131) patch to Zwift, macos (14.6.1) was unable to see the Kickr Core.
The Kickr Core was however able to be seen, connected to, and used by my Apple Watch (11.1 22R585) using Bluetooth and the Workout app. So it seems as if this is a problem with the latest (1.77.0 136131) patch to Zwift on macos (14.6.1).
Anyone seen this and have a solution? Problem only appeared in the last 2 days.
Seeming solved by updating Kickr Core to firmware version 1.5.36; will close after a full test is complete.
I’m not sure if updating Kickr Core to firmware version 1.5.36 solved the problem or if updating simply occurred coincident to the problem being solved through some other unknown means. Regardless, it now works.
