From 5/24/21 in my result I have always ZP status, what the problem? I have change anythings on my trainer and heart sensor.
Thank’s
ZP means you are racing without a power meter (or trainer containing one) and instead your power readings are being estimated by Zwift. Most races require a power meter and will disqualify you from the final results if you don’t have one.
If you haven’t changed anything with your setup, you should check your power source is being paired correctly to Zwift.
