zFTP going down while VO2 max going up
I haven’t really thought through this but my zFTP has been steadily decreasing recently while my VO2 is increasing nicely. This seems contradictory to me, am I misunderstanding something?
Additionally, I have just come back from a substantial break from Zwift and I am seeing my 20 min best efforts as either steady or gradually getting better too so again I am surprised to see zFTP going in the other direction.
All figures are based on race performance. As I type the only thing I can think is that data from earlier in the year is being lost / no longer included so my zFTP is kind of resetting (I stopped on Zwift on the 2nd of August and started again on the 4th of October).
This outcome sounds normal. If zMAP goes up, zFTP goes down, and zMAP is a reasonable proxy for VO2max. It is a bit counter-intuitive but that is how it works.
This would be accurate and is normal under most models of power output. As you increase short power capabilities, generally the curve will become a steeper angle and vice versa; as your endurance power increases, generally your short term power will decrease.
This would be normal as the body adapts to whichever you generally work on, and models to date have backed this up… essentially, do something more and you get better at it, do something less and you get worse.
Reminder that zFTP is not FTP but critical power.
All of that to say, it’s not impossible to raise both, but generally if you know you’re at your limit, working your short term power will come at the loss of long term power as your body adapts to different muscle usage.
Today I had the pop up at the end of the race that my FTP had gone up from 331 to 335, while my zFTP went from 323 down to 319.
Ignore it. zFTP is not a useful measure of anything.
but it does set your category for certain racing series like ZRL, so it is being used…
