Why do a yellow triangle apear With a message
Saying you should be a pro and saying Zwift trainer is not set up right
What can I do
There were 5 riders in front of me
Then after triangle the speed went down
I was faster with cup of tea on
What can I do
What sort of trainer are you using?
Swift trainer first one they brought out
That is odd. I would apply any available firmware updates, but if it’s already up to date you should probably contact support. There may be something wrong with the trainer.
Ok thanks
Shuji at Zwift HQ. Your FTP is set high, even for a professional cyclist. If you use one of our FTP test methods to benchmark your current level of fitness, the cone of shame should go away.
Done a ftp Test
You said to high
How can I lower the ftp to the test result
