After having enough of triple twist with Coco, I turned off and after going through the desert and heading to the coastal roads the minimal read jungle ruins.
I think that is telling you the next intersection is at the jungle, since it doesn’t know where you are going since turning off the chosen route.
Isn’t that the recent changes that were made?
I found some info:
The player pin will stay in position on the left side, with the terrain moving right to left. Players will see the next upcoming 3km.
The name shown here is the name of the most recent intersection you went through.
The distance shown here is how close you are to the next intersection.
At the next intersection, if you choose a different option, the profile will update to show you what is coming up.
@Mike_Rowe1 is exactly right.
The text will show the next intersection.
Previous actually
The next intersection would be the grade or continuing the coast though.
I’m not so sure about that.
Here’s one I rode where I finished the route at the top of the Petit KOM, and the intersection text shows Ventoux Summit.
I’m quite certain that the Ventoux Summit was NOT the last intersection I went through before completing the route.
The turn indicator option box at the bottom of the screen matches the text in the MiniMap also - Ventoux Summit.
Ya I guess that’s the current behavior. It chooses some point up ahead and just uses that intersection name.
