Since the most recent Zwift update I am having an issue with the Zwift workout mode. I am running Zwift on Mac OS X El Capitan.
Basically the games loads up fine to the screen where you can choose to “just ride”, ride with someone else, or enter the workout mode. If you click on the workout mode, Zwift instantly crashes.
On the next login following a crash, Zwift won’t recognise any of my sensors - no power meter, cadence / speed, or heart rate monitor. But if you then close down Zwift and login again, the sensors are detected.
The ordinary riding modes - ie just riding, or riding with someone else - work absolutely fine. The crash only occurs when you try to enter the workout mode.
I get something similar with el capitan, everything works fine until I reach the climb area of the course, then system crashes at the same point, when I log back in all my sensors are lost
Had exact same issue at the weekend except that I was not using workout mode. Crashed then didn’t recognise sensors then all ok on the reboot. Mac and El Capitan.
I have a similar problem. All works well until I select workout mode. The program crashes. I have the same problems with the 2nd start of the program. Also running El Capitan!
Same here! When I press ‘Select workout’ the program freezes and I can’t do anything but restart. Even if I reboot my entire computer, it doesn’t work I’m on Mac OS X High Sierra.
