Workout in event
if I’m joining an event with a workout, is it possible save this workout to do it again?
Or maybe extract it from the fit file?
Thanks!
Is the workout not available from the on-demand list in the training menu on Zwift?
I mean if it’s a custom workout
They should be able to email you the file and then you can import it to Zwift to use again. I think?
If they will NOT send it, this is the question what I can do.
Well I’ve never tried this, but it might be a solution for you?
I’ll give it a try, thanks!
Not working from a normal fit file
FAQ: Why does my .fit file give an error upon conversion?
The workout converter only supports workout ‘recipe’ .fit files, not recorded workouts. To convert a recorded workout to a Zwift workout .zwo file it is possible to use our GPX to ZWO converter where you can use a .gpx file of the recorded workout (instead of the .fit file), which typically can be exported from Garmin, Strava, etc.
