Workout Builder Problem - Long Duration & Short Blocks Not Selectable
(Michael Henasey) #1
I wanted to point out another minor problem with the workout builder that you are probably aware of…
When you have lots of blocks and some of them have very short durations, it becomes impossible to select and move them unless you first increase the duration/size of the block.
In my example below, I’ve created a workout with individual blocks and intervals. The very short blocks after the warm-up are impossible to select and move unless I either (1) increase their durations or (2) shorten the entire workout. Notice the workout time is 3 hours 30 mins. When the total workout duration is only 1-2 hours, the blocks scale larger in size and are selectable. The blocks that are not selectable in this example have durations of around 1 min.
