IS there a work around for getting Zift to work in a Windows VM?
Thanks,
David
Thanks,
David
Even if you get it to work, it will be truly awful. If your host OS is Linux, there is a pre-built docker image you can try.
I have a Macbook Pro, but Because Saris decided to screw us Phanton owners by selling us expensive trainers only to abruptly stop supporting them (via software), I had to download and install PerfPro CT Bridge. It can talk to Zwift, but I had to use a Windows VM (on my Macbook Pro to use it, I figured since I had the VM up and running why not use Zwift on that too (instead of running that outside of Windows on Mac.
Running Zwift natively on your mac will perform far far better.
