Haha, cracking!
Thank you. This workaround worked for me. Hopefully, gstatic wonât be crucial for something else Zwift.
Same issue today but different script. Mine still has launcher 1.0.0.0 (12-Feb), ZwiftApp updated 24-Oct.
Same workaround applies.
Updated windows, reinstalled Zwift a number of times, blocked gstatic but this is how far I get, canât get past the ââRideonââ screen, any ideas /
Thatâs a separate issue, youâd be better off creating a new thread detailing your full system specs.
the fix was easy, now it says my password is no good, which is bull because I logged into zwift dot com with it
wtf?
No idea Iâm afraid, blocking that domain has nothing to do with your password. Worth asking support to reset it for you.
okay, itâs working, not sure what happened, thanks
itâs amazing how addicted I am to riding, lol, I thought âmy day is ruined! waahhhâ
I am also having the exact same issue. I deleted Zwift, reinstalled it, still does not work. Loaded the app onto my iphone to train at this pointâŚwhat is the fix?! I also tried the language setting suggestion, did not change anything, and also changed my password, that did not change anything.
Thank You! I will give this a go tonight!
First time trying zwift out with my new wahoo kickr core⌠but I can not log in to zwift. First error I got was for the gstatic error. I did all the steps above⌠now its a recaptcha error⌠i have clear my cashe and problem persists. Will we have to wait for a update from Zwift to use?
I tried the Gstatic tips over with no luck. Then i took away the remember password and changed it. Then i was able to access the site again.
The trouble have been there since 20 october! Should be fixed soon.
Thank you!
Hello!
i get this error and the gstaic workaround does not work.
anyone with a idea how to workaround it?
click yes
Scroll up for more info.
yes or no does not help the zwift launcher is just white anyway and nothing happens
I have try that and still same issue. Maybe worth to mention is that zwift launcher was white during update that did occur after the installtion beside the text and progress bar in the bottom.
