Wild Wattage Fluctuations
(N ooBie (D)) #21
I am also having wild fluctuations. I have a wahoo kickr snap and using a MacBook pro. I have tried using both Bluetooth and ant + with the dingle literally next to the kickr.
When the Bluetooth companion capability came out that seemed to stabilize the fluctuations. However, now no matter what connection method I use the fluctuations are there.I have even tried mix and match. I…e. Heat rate and cadence on ant+ and power and source on companion with same results.
Any suggestions would be greatly appreciated.
Respectfully,
Robert
(David Hancock) #22
Hi all,
Here’s what fixed it for me.
I have had the Kickr for 6 weeks with absolutely no issues…loved every second on it. Then 3 days ago the symptoms described by you all in this thread started happening to me. I had changed nothing in my set-up to warrant this ugly behaviour…wild swings in power output despite a consistent 90rpm effort and complete losses of connection (0) watts. So I started reading all of the suggestions on how to fix it and here is what I found…
  1. I decided to start making 1 change at a time and retest between changes.
  2. Change 1 - I deleted and re-installing the Companion App on my phone …this did not fix it. Same symptoms when I tested.
Then I noticed that it was taking longer to connect to my Wahoo Heart Rate Monitor than normal. In fact it was looking for so long I cancelled and tried again. So I wondered…even though the HRM was only 4 weeks old could the battery be flat?
So I replace the battery in my HRM and voila the bluetooth connection was again back to immediate.
So I jumped back on the Kickr and tested again and bingo no more fluctuations in the watts.
So I can only assume that the poor HRM signal was somehow confusing the whole set-up or somehow interfering or maybe the App was continuously trying to reconnect and in doing so upsetting the connection to the Kickr as well. Who know s but my problem is gone.
So I’d suggest that you try replacing all your batteries (Cadence etc as well).
Cheers, Dave
(Gerhard Wessels) #23
I have a Wahoo Fitness Tickr HRM, Blue Speed & Cadence Sensor - 6 weeks old and a Wahoo Kickr Snap 2 trainer, 1 week old. Zwift is running on a Mac Mini with OS X installed. I see no dropouts on the graphs at the bottom of the Zwift screen and yet my power isn’t stabilizing even at a constant 90rpm. I did the FTP builder program and I scored 2/8 just because I couldn’t hit the target power. Cadence was never a problem since I could control that directly. I had better success when I switched off ERG mode.
All my devices are always picked up instantly and I don’t get dropouts that I can see.
I will do a test without the HRM to confirm but I am not hopeful.
