Why can't I draft in Zwift?
I’ve been on Zwift for several years. I used to be able to draft. That is, when following closely behind another rider, I could ride at ~ 0.3 w/kg less than them and keep up. For approximately a year, that has not been the case. I regularly ride on Zwift with the same people. When they are drafting me, they’re able to do it at ~ 0.3 w/kg less. When I draft them, I have to be putting out the same w/kg as they are. I’ve checked my height and weight in my profile. I’ve ridden different bikes. I’ve experienced this on my old Saris trainer and my new Wahoo Kickr Core 2. I deleted the Zwift app from my AppleTV and reinstalled it. No change. I can’t draft. I’m not the only one. Every so often I run across another Zwifter with the same affliction. I’d guess that maybe 1 - 3 % of Zwifters have this problem. I tried “height doping”, decreasing my height by 1 foot. This may have gained me 0.1 w/kg. Should I Zwift at 2 feet tall? No, I should not. I used to race on Zwift. Not often, or well. I have no incentive to do so now. Any ideas?
Useful information would be:
Height
Weight
Bike*
Upgrade level of that bike
Route
:+1:
*just tell us the one you ride most often
Also would be useful to know if the draft bar is shown on your ride.
Maybe a screen shot would be helpful to understand is it you are getting no draft and zwift is doing it or you are getting draft (as per drafting bar showing) but then for some reason you feel you are having to match power)
The two main things i can think of are first you are on a tt bike but you say you have tried bikes so unlikley.
and secondly if you are significantly lighter than the average zwifter you will need to put out more w/kg than others to ride at the same pace
Here are some things for you to consider:
Are you testing this in a controlled setup riding with one or two people you know?
Or
Are you observing this in group rides whilst trying to look at the w/kg of others around you?
Many of the group rides you are doing, and staying with the group, are banded rides where there is no drafting.
A year ago you were 78kg now you are 72.7kg.
A year ago you were 183cm tall you are now 188cm tall [you used to be 188cm tall then 185 then 183 - not wishing to be rude but at your age I might expect that sort of drop in height but not the return to 188]
These two things might have an affect on your drafting.
Your screenshots show the draft indicator so you are riding a bike which offers draft benefit.
Try and avoid riding your Tron which doesn’t show the rider changing position when in and out of draft.
This might be the difference. They said it happened about a year ago, and at that time if they were doing the same w/kg on flat as someone while 78kg they would be doing more power than doing the same w/kg at 72.7kg. So if all they are looking at is the w/kg numbers and they are drafting on flat they will notice a relative drop in w/kg differences.
Like, to give a more extreme example.. if you put your weight to 50kg you will need to do more w/kg than someone at 100kg on flat - if they are doing 300W at 100kg (3w/kg) at 50kg you will likely need more than 150W to keep up on flat.
What bike are you using in Zwift? Not a TT bike by any chance?
And for that matter, on climbs the super light 50kg (or even less) riders doing the same watts/kg as me, I usually ride away from them uphill (despite being heavier) - often ending up over a minute ahead. Just being light on its own isn’t always enough.
Thanks for all of the questions and comments. I did find that I’ve had my height entered incorrectly in the past. Also, I did intentionally lower it by 30 cm for a couple of days to see what effect that had, if any. My height is 188 cm. My weight is 73 kg. I’ve been leveling up the Tron (slow process), but I switched to the Canyon Aeroad for several rides. And I have verified that riding the Specialized Tarmac (the three that I have) does not make a difference. There was no change in my drafting ability. The drafting bar displays correctly on my screen and drafting power-ups also display correctly. I have taken to riding more banded rides since I CAN’T DRAFT (sorry about the caps). But I ride several non-banded group rides, mostly EZR and Bikealicious. I used to get a draft benefit in these rides, but now I do not. I ride with three other riders regularly. One is 191 cm and weighs 100 kg. Another is 173 cm and weighs 91 kg. The other is 178 cm and weighs 84 kg. When I am drafting any one of them on the flat, I need to put out the same w/kg as they do to not drop out of their draft. When any one of them is drafting me, they can do so at ~ 0.3 w/kg less than me, on average. Watching the roster on the right of the screen, I can see in group rides that almost everyone can draft me and put out ~ 0.3 w/kg less than me and stay in the draft. And I have to put out the same w/kg as almost everyone else even when my drafting bar is showing that I have the maximum draft. Also, as I noted, very rarely I find another Zwifter who seems to be experiencing the same phenomena. But very rarely. Next experiment: I’ve set my height in my profile to 152 cm. I’ll try that for a ride or two and report back.
Id be interested to actually fan view you to see the data on draft (via sauce) as you can see how much riders are getting.
Also this might be of interest
In terms of what you said about following heavier riders you have having to put out 0.3 w/kg is not a surprise certainly for following a 100kg + rider.
i always use to have in my head for every 10kg in weight you need to do about 0.1 w/kg more
But i would have read of that watt wasting article is quite interesting
In terms of what y
What about leaving your height at your real height and getting some video captures of what is happening?
Then we can see better what’s happening. “Experimenting” with heights and weights isn’t all that helpful.
That explains it.
W/kg does not equal speed. Heavier riders go faster at the same w/kg regardless of the terrain. Being taller has an impact too, taller is less aerodynamic so slower.
The question of whether or not you’re getting draft isn’t answered by comparing your w/kg to those around you, you need to compare how much power you need to do that speed on that terrain when you’re behind someone vs when you’re on your own
If you put your weight to 100kg you will notice a w/kg difference when drafting someone who is 100kg.
Gordon, Thanks for the link to that article:
“The range of watts between minimum and maximum is large, which means you can waste a lot of watts in this situation. For example, in my video below, I show how you can sit on the wheel of a rider holding 300W at either ~230W (the minimum) or ~295W (the maximum). That’s a 65-watt swing. That’s big!”
Both 230W and 295W are less than 300W. If both riders weigh the same (the article doesn’t say) then the lead rider would be putting out more w/kg than the following rider. I agree that when riding solo (no draft) that a heavier rider will put out less w/kg than a lighter rider (assuming equal aerodynamics). But at 30 kph and above the effect of the draft should be as dramatic as that article indicates, i.e. the drafting rider should be able to put out 230W and still draft a rider putting out 300W. While w/kg is the wrong unit to use for my drafting comparison, it’s the one that Zwift furnishes. I’d very much like to see what the watts the rider that I am attempting to draft is putting out. That said, taking my largest friend for comparison, my weight is only ~ 73 % of his weight, so if I were putting out 230W to draft his 300W, he’d be showing 3 w/kg and I’d be showing…3.15 w/kg. In that case, I do have to be showing the same w/kg (or a little more) to hold the draft. But what I’m seeing, ~ 98% of the time, is that when I’m riding next to another rider on Zwift, we might be showing the same w/kg. When I drop into the other rider’s “draft”, I still need to put out the same w/kg (i.e. the same watts). But when they drop into my “draft”, they can back off by 15 - 25%.
Not really seeing or hearing anything that sounds out of the ordinary here.
In a paceline, I’m usually around 59kg average, TTT style if I’ve got a guy in front of me in the 70-75kg range doing 5wkg, in 2nd position I also have to be holding at minimum 5wkg to hang onto their wheel. Anyone heavier putting down those numbers and there’s not much I can do, they will leave me on anything that’s not The Grade or Radio.
For the record, this is why TTT calculators exist for teams, so you don’t stuff your lightweight behind a heavyweight.
All it sounds to me like is OP has found heavier riders than himself for the first time.
When Makuri Pretzel (mostly flat) was released I did it in a free ride and joined up with a guy who was motoring along at about 2.5W/kg, and I thought cool I will sit on this a bit. OMG he was so big, it seemed like I got zero savings. Of course that wasn’t true, he was just a fit giant so my expectation based on W/kg alone was misguided.
You know what’s funny is I think my experience with Makuri Pretzel the first time is the same but literally the opposite. I saw someone going kind of high pace (for the length of the the route), mid 3s or so, enough for me to hang onto, making good progress up the rider list.
They finally got up to me and zipped right by without issue on a Tri frame, and I was like what the heck was that?! Spectated their power and it was similar ish.
Then looked them up on ZPower and realized they had their height set to the minimum…
I really appreciate all of the responses to this thread! My weight pretty much guarantees that I can always find both heavier and lighter riders than me (taller riders, not so often). I rode ToW stage 4 standard last night. My friends didn’t show up. But I settled into a group with four other riders and we rode the whole way together at ~ 2 w/kg. I had an hour to watch the w/kg of the five of us, from all the different positions in our little pack. Two of the riders seemed to be able to drop their w/kg significantly (~0.3 w/kg) when they were drafting. At the end of the ride, one of those two riders said that he was very heavy (“fat ■■■■■■■” was the term that he used). The other three of us seemed to have to be within 0.1 w/kg of each other to hold a draft. My 173cm/91kg friend is the best drafter that I know. He uses this to his advantage in both group rides and races. Strong, on the heavy side, and on the short side. Next time that I ride with my friends, I’ll see if we can compare watts while we’re drafting.
Bottom line. You are all correct. Drafting appears to be functioning normally for me. Why I seemed to be able to lower my w/kg when drafting previously (when I was only 5 kg heavier) I have no idea. My height and weight are set accurately in my profile. So, more riding, less whining. Thanks for the help!
Just ask anyone in Watopia if they want to climb Epic or Volcano or anything else. The faster they respond is correlated to how heavy they are :joy:
Must be said that even on steep climbs the slightly heavier riders can get away from lighter ones at a bit less watts/kg. I do that regularly to the folks who drop themselves to 35kg or 45kg.
If it’s a flat route, I’m finished. No matter how much people say smaller folks have advantages there too. Not me! I have to do way more watts/kg to stay with them. Downhill even worse, although some 35-45kg people must have a technique for going quick downhill too…
