I’ve been looking around but can’t find it: where do I put in my own weight so I get the correct w/kg-value?
Everyone is set at default 75kg for the time being. Leader boards might change when real weights go in!
Ah, thanks.
Are you going to implement the ability to enter your weight because assuming everybody weighs the same makes it impossible to compare times with other people as nobody is actually traveling at the correct speed unless they actually weigh 75kg.
Its a shame this wasn’t implemented at the start as the Strava leader board is complete rubbish as a result and will never get fixed unless people voluntarily remove their rides.
I like to know the weight of the AI rider that completed the 200m sprint in less than 5 seconds!
