What's the best ANT+ to Bluetooth device for Zwift use on iOS?
(Effective Challenge) #1
What’s the best device for connecting up my ANT+ sensors to Zwift for iOS. My research so far suggests I need a bridge. It’d be good to know which is best before buying one.
Many thanks in advance,
Damian
(Paul Allen) #2
You can use you phone and bridge the connection using the Zwift Mobile App or you can get an adapter and use the Wahoo Ant+ key.
(Effective Challenge) #3
Brilliant - thanks Paul.  I’ll give that a shot.
(Phil Clarke) #4
Hi Damian,
I’m new to Zwift, so I’m still figuring everything out.  Just started my free trial last Saturday.  Here is some information I came across when trying to solve the same problem.  My MacBook Pro is 8 years old, so I was trying to find something which would allow me to use my Garmin ANT+ devices with Zwift on my iPad.
here are a couple of other options:
– HR monitor which will act as an ANT-to-BLE bridge: Viiiiva Heart Rate Monitor from 4iiii
http://4iiii-innovations.myshopify.com/products/viiiiva
– dedicated unit which will Connect ANT and then rebroadcast as BLE:
http://www.npe-inc.com/products/products-cable.html
There’s a bit more info describing them contained within this article:
https://www.dcrainmaker.com/2016/11/hands-upcoming-running.html
I can’t say anything for the 4iii device – seems like a good idea and the company appears to be reputable.  But I did order the CABLE device from NPE.  I have used it once so far, and seemed to do the trick with no issues.
Best of luck!
phil
[I have no affiliation with any company or person mentioned herein.]
(Kin Chen) #5
Add one: https://play.google.com/store/apps/details?id=chan.jas0n.ANT2BLE_PowerMeter
(Neill Campbell) #6
I use a bluetooth bridge that I am liking quite a bit.
Hereis a link to my review of it. it’s the CABLE product. Wireless bridge.
(Jan Skrbek) #7
Hi, I want to ask Paul: how did you bridge ANT+ to Bluetooth using ZML? It seems to me it allows me to connect only to bluetooth sensors (which I don’t have…). And yes, my Android phone supports both BLE and ANT+.
(Paul Allen) #8
Jan,
The ZML only bridges Bluetooth, you would need something like CABLE to bridge ANT+.
(Ewan Hackett) #9
I don’t know if the wahoo is the same as mine but I have an adaptor. It’s a thunderbolt to 30 pin connector and the adaptor sits on he end of that.
What I’ve found is if I plug the converter in first
Then load zwift
Plug the converter in
Ant doesn’t show up - click skip
Then go back to pair as above
And it’s there
Hope this helps
(Esteban Toha) #10
Hi! My name is Esteban and I’m new in the Zwift world. I have a Tacx Blue Matic trainer, the speed and cadence sensor from Garmin and the Garmin stick for ANT+. However, I want to use my iPad pro to train with Zwift, the thing is that iPad do not support ANT+, so I have to use Bluetooth. Reading the comment I see the bridge option ,however, can I use the speed and cadence sensors from Tacx? I understand that the device transmit ANT+ and Bluetooth, it is possible use this sensor and get the readings direct from the iPad? To avoid the use of CABLE+USB ANT+ stick+speed and cadence sensors from GARMIN I will apreciate your help!!!
