Correct, in free-ride sections or if you turn off erg mode while in a workout it puts you in incline/slope mode where the trainer holds a set gradient which you can adjust up/down and also use your gears to change resistance.
right on cue!
The answer is on Zwift insider, it was just posted
More specifically, the answer is in the comments on the Zwift Insider article…
You are absolutely correct. Tested tonight and if you come out of ERG you go into whatever incline level you have it set, nothing to do with world terrain.
