What is the exact spec for the Zwift Ride thru axle?
Hi, I see that the Zwift Ride uses a 142 mm thru axle. I was wondering about the exact spec:
  • 12 mm axle diameter, I assume?
  • 1.5 thread pitch?
  • Flat head or cone head?
  • Nut to end length?
I would like to be able to order a spare axle and so need to know the exact spec to order.
Thanks for any info!
Hi @Gwydion
Shuji at Zwift HQ here. I measured my axle for you, this is not an “official” spec.
The Zwift Ride thru-axle uses the Syntace axle spec, which are distinguished by:
  • 12mm x M1.0 thread
  • Beveled bolt head - I think what you called “cone head?”
Additionally:
170 mm total length including the thickness of the bolt head.
165 mm if measuring only the 12 mm shaft.
Perfect :folded_hands: thank you so much!
So they are from France? :laughing:
